Ok so here is what im working with
r33 Gts-t
full exhaust
EBC
Now is the time for a FMIC and I was wondering if this option could give me less lag as the piping will be shorter
as you can see (dealer dosent have a pic for the r33 model) ... the piping is almost identical as stock
any feed back would be great !!
https://www.sau.com.au/forums/topic/224559-fmic-and-lag/
Sure less piping but the air at the end of the tank hits the flat end tank then has to perform a harsh 180degree turn to head back through the fmic = quite a large pressure drop. But it will work.
As for whats better. This setup or a pipe that does a 180degree bend and then travels back I'm not sure.
Unless you go back to back you probably won't notice.
https://www.sau.com.au/forums/topic/224559-fmic-and-lag/#findComment-3955071
Maybe you might be able to record some sort of pressure drop when running high boost applications.... but i run 12psi with a Blitz Lm Return pipe and there no pressure drop..
there IS a slight lag as the much larger cooler is filled compared to the stocko item but this is the same with a straight through fmic. I think at the 200kw kinda world where most people with pretty stock cars are sitting... you wont notice the difference. With a 300kw rb25... well that could be a different story.
Cheers
Camden
https://www.sau.com.au/forums/topic/224559-fmic-and-lag/#findComment-3955600
Im running a fairly crappy setup.
A 450x300 with small 2" piping.
My piping does a full 180degree bend in to the fmic on the drivers side running up underneat the fmic; so not quite as nice as the Blitz setup which has the end tank designed to accommodate the 180degree bend some what from memory?
Mines making 268rwkw on 15psi and doesn't appear to be having any issues at the moment but its definitely not optimal. :S
https://www.sau.com.au/forums/topic/224559-fmic-and-lag/#findComment-3955923
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
