standard nissan filter will do the job great.
I use Cooper filters that the local parts store keeps in stock. I once read a comparison of "3rd party" filter brands that the Cooper filter did a bloody good job. See here:
http://www.aus-cartalk.com/auspoc/techstuff.htm
Remember that the manufacturer filters are usually just other brands with the car maker's name stamped on it instead. So you're relying on your car manufacturer to specify a filter that does a satisfactory job (comes down to a trust thing really!).
The cooper filter base plate looks just like my Nippon Micro base plate. I wonder if they are from the same manufacturer but different brand?
Mobil is a true PAO synthetic oil with added esters. Contains good levels of detergent and anti wear addatives.
Motormates also do the Purolator oil filters.
Mobil 1 does not have any esters :unsure: They use alkylated naphalines in its place now. Purolator Pure 1s are damn good filters for the money. I'd rather pay for a Pure One than get a free Ryco.
Links, the 8100 is a good oil. But if you can get the Mobil 1 0W40 at a similar price, then get it because it is superior.
I disagree. Ran Mobil 1 in the pulsar and it went off very quickly, and before the service interval. It went from the high mark and light brown to the low mark and dark brown in the space of 2 weeks and an old pac run. My service interval was 5000km which should be very very conservative on a stock SSS.
Motul 8100 never used a drop on my RB20 over 5000km and came out still looking great.
I dislike oils that go off that quickly. Castrol Synth-R was also low on the dipstick after only 4000km on my RB20.
Stick with the Motul 8100. You can't go wrong.
An oil that goes dark is cleaning and suspending crap better than an oil that doesn't.
I'd much prefer my oil to go dark than stay light.
If its using oil... Then for the given motor its too thin, castrol 5w30 is too thin for my rb30det as it uses around 500-1000mls per 5000kms. throw a 40 weight in it and it doesn't use a drop.
Depends on the cars condition and how you drive.
Lots of short trips you are better off every 5000k.
Hows your fuel economy? Fuel economy is an indication if your dumping fuel in to the oil excessively.
To truley know you need to do a few oil analysis.
You are comparing 2 different oils running in 2 different cars??
Mobil 1 0W40 is probably their best M1 range they offer here in Aust. It meets MB 229.5, where it is used in cars who's OCIs of 30,000ks+ are the norm. For it to go 'off' in under 5000km just by looking at it is just an assumption, especially with no oil analysis results. smile.gif Perhaps the thinness of the 0W40 promoted more oil consumption, same with the Castrol R 5W30.
I suggest you try comparing the OEM certs between Motul 8100 and M1 0W40 and you'll see which is superior.
Sir-D, Helix Ultra will do a 10,000km OCI comfortably on a stock motor, providing its in good condition.
An oil that goes dark is cleaning and suspending crap better than an oil that doesn't. I'd much prefer my oil to go dark than stay light.
Good to know and I agree with you on the first point too.
Just for reference I am using Mobil1 5W50 in my GTR and its not 'using' any at all.
Its also gone quite black since my February oil change.
Have to say that Shell Helix Ultra is performing pretty well in my car. Economy so far seems pretty good. Just got under half a tank of petrol and the car has done around 250 KM... car is auto.
Also the revs are smooth and no harsh noise.
SHU is consider kindda >_< over here due to it's sluggish performance and high cost for a group III oil.
Well busky2k i couldnt get the mobil or the motul as i went to supercrap and they dont stock it, i ended up buying the 0w40 castrol edge and a pure one filter. It should do the job.
Once again thanks for all your advice.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
