Aghhhhh! I can't find the Mobil 1 - 0W40 anywhere! is it the same as Mobil 1 Gold? Spare part shops are quoting me $80 - $90 for 5L... That’s bit much IMO
A few performance shops recommended to try Valvoline SynPower 5W40 and they swear by it... A motor oil test comparison showed that the Valvoline SynPower was up there with Mobil 1 and in some cases better then Castrol...
http://www.synthetic-oil-online.com/10W30API.htm
The site is bias "propaganda" for AMSOIL but shows a fair comparison beween the other oils...
Any one used Valvoline SynPower??
I think at the end of the day, as long as you use a decent grade/quality of synthetic oil.. with regular intervals (5000kms/3 month) oil & filter change, your car will run purrrfect...
Any oppinions would be greatly appreciated!
Regards,
Sarkis
Regards,
Sarkis
I would say choose a good synthetic and go 10k OCI, it's cheaper and protects better than the "avg synthetic". Cost per mileage will be cheaper.
Everyone know that Amsoil website is pure propaganda and can't be taken too seriously. Take it with a pinch of salt.
Edited by Trex101
During my break at uni today I managed to take a quick trip down to Peps and Super Cheap... This is what I found (all are in 5L jugs):
Mobil 1 5W50 - $69
Mobil 1 GOLD 10W30 - $79
Royal Purple 10W40 (at Peps) - $75
Royal Purple 5W30 (at Peps) - $72
Castrol EDGE 0W40 - $70
Castrol EDGE 5W30 - $49
Valvoline SynPower 5W40 - $45
Wouldn't the choice go to Royal Purple for the high range? and the Valvoline Synpower for the low range?
What you think guys? or am i going around in circles chasing my tail? :O lol
I wouldn't mind spending $75 for the Royal Purple, but considering i change my Oil/Filter every 5000kms I think the Valvoline or Castrol for $45 - $50 would be a good choice...
Cheers,
Sarkis
Edited by QRI05E
Mobil 1 5W50 - $69 --- too thick
Mobil 1 GOLD 10W30 - $79 --- abit expensive but still ok
Royal Purple 10W40 (at Peps) - $75 --- ok
Royal Purple 5W30 (at Peps) - $72 --- ok (depends if you are running rich AFR)
Castrol EDGE 0W40 - $70 --- ok
Castrol EDGE 5W30 - $49 --- (could be group III, good enough for NA engine)
Valvoline SynPower 5W40 - $45 --- group III (avg oil)
What you think guys? or am i going around in circles chasing my tail? :D lol
Cheers,
Sarkis
For the above available choice, i suggest you go for RP 10w40 and run 10k. The HTHS for RP 10w40 is pretty strong at 4.02
hmm all this advice is getting me confused.....
What grade oil is best for a series 2 33 gtst running 192rwkw...
I was thinking of going Mobil 1 stuff...
Whats the best oil in ur opinion 'value' wise, if ur changing oil every 5k?
any help would be great thanks.
in my opinion motul Chrono 300V. it's a very high quality oil, full synthetic ester. run it for a while and should you ever have to have your rocker covers off you will be amazed at how clean your engine is. plus it gives great protection even at higher temp. I wont use anything else in the GTR anymore. for me i think it's worth every cent for the knowledge of having a high quality oil in your engine.
franky, are you running the 300V or the 4100? your post wasn't clear. cause they are VERY different oils.
Motul Chrono 300V how much does this set you back? are you changing your oil every 5k? and what weighting do you reccomend for my application?
Thanks for the help.
im using 4100 atm, but want a change sometime.
due to the car running rich, the oil has been changed quite often....used 300V Chrono last time, for some reason i wasnt very impressed. i was told by a mechanic that fully synthetic oil actually drains from the head, and thats why nissan recommanded blended oil factory.
i am very confused. once the tuning is done, im gonna reset the valve clearance, and then use 300V 10W40 again, and see how i go.....
thanks!!
Edited by frankxinyu
300V Chrono is 10W40. I change around 2000kms simply because car does not do that man kms but does do around 8 days of track work a year so it gets changed every second track day. it's quite expensive but in my mind the best. i get very good stable oil pressure, even when temp is up around 110 degress. monitored using a defi gauge so no dobut as to the accuracy of the pressure reading.
fanky, RBs dont have any real problem with oil draining away from the head. and if they did oil viscosity would affect it, not oil type. so that guys info is not entirely correct. give the 300V another try.
I was told by a mechanic that fully synthetic oil actually drains from the head, and thats why nissan recommanded blended oil factory.
thanks!!
The fact is all engine oil be it synthetic or mineral (other then ester base fluid) will drain down to the sump after a period of time.
That's why Motul 300V or Redline oil cost so much as they use ester base fluid which is polar in nature and "cling" to the wall without ever draining dry.
I would go with Redline if budget permits as they use polyol ester as it's base stock (there's alot of different ester). polyol ester is the only lubricants which can withstand the tremendous heat of modern jet engines.
Polyol Ester
Polyol Ester
Starting to sound like a salesman there lol. Pity Redline still leaves alot to be desired in terms of antiwear performance from a UOA point of view!
UOA is pretty avg for normal day to day use but it is under race and track condition that RL excelled.
Can't say I've ever seen an RL UOA when used under race conditions.
Care to post a linky?
Ok, not race but hard condition, this is 2 example where i did a quick search. There's more UOA in BITOG i'm sure though.
S2000
My Webpage
Accord 2.4
My Webpage
Then again there are plenty of other UOAs where in track conditions other oils have excelled too.. and there are always excuses for RL's poor performance. "Must be doing some cleaning" or "Interacting with the bearing overlay" or something else. Yet we don't see the same arguments for other oils, especially ester based chemistries.
Ok guys, I emailed Royal Purple, regarding the grade/quality/group of their oils and they stated that they use a group V base and the rest is their Synerlec technology which has proven itself over and over again... even my mate's auto shop oil supplier who sells Motul, Red Line and RP said that RP was the best oil he has ever sold and used on his R33 GTR ~290aw/kw! Horses for courses I guess...
Today i picked up a 5L jug of Royal Purple 10W40 from Autobarn along with a Cooper oil filter... and hopfully ill get a chance this week to change the oil and will post the results...
Cheers,
Sarkis
Cheers,
Sarkis
price for the RP?
I need oil by Monday and im running out of ideas lol!
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
