Just stick with the 5W30 in summer. There's no real need to go thicker as the oil temps will still roughly be the same when its the motor is hot anyway (as the coolant indirectly will remove the heat).
and ur cold start cSt rating will be like much less thanthat of the 10W40....
one question for Busky and trex...I use a 10W30 in my fto and is the goods....I had been using a 10W40 Redline in my Rb25...what u think about lowring it to 10/5W30 as we move into summer...prop. the same as post above.
its a rb25 worked to 300rwkw...I went the 10W40 redline as I thought it to be a good general thickness...yeah might gove the 30 a go...
what weight and brand do u use??
What's your avg oil temp?
A general rule of thumb is to increase oil viscosity by a grade if oil temp increase by 10'c.
hi, im the guy who used to put repco semi synthetic in his r33.
I did my oil change last weekend using mobil1 0w40 and omg can't believe how much smoother it is now. (either mobil1 really good or repco oil just pure cr*p) for some reason i have a feeling its the second one
khunjeng, stay with Redline, its a good oil. Or Motul's 300V "Double Ester" formulation looks great too (mega dose of Moly!).
I'm going to stick with the redline for sure...I havn't got a oil temp guage - i was going to install one but then didn't. Maybe its a must - I assume its hotter but then again I only take it to the max on the odd occassion and its driven on the street.
btw Trex..finally got into the BITOG..saw a few of ur posts...just sussing out UOA now and will post some results using the 10W30 redline.
Have you found a UOA kit yet? Which company are you senting for analysis? I'm now using Wearcheck usa
yeah I have and got the sample sent to me already. I used a company that Busky2k gave me...I will chnage the oil and take the sample and send it off..I'm excited :laugh:
Been busy changing ATF and GB and DIFF oils in other cars...omfg ATF changes suck arse.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
