And how come my oil temp nevers goes above 70?
You mean after warmup and >20min driving, you got oil temp of 70'c? A normal engine after warmup need about 80-90'c oil temp to effectively burn off combustion by product/water that get's in the oil.
Anyway where did you live where temp drop to -40'c?
Ive got a HR31 with the older redtop motor, its got apparantly 100,000 on it but its probably more like 150, anyway it blows no smoke and has even compression all over the board so it's in good condition. Pretty much stock standard but it does get quite hot in summer (sits on half temp - should get a proper guage though)
Anyway I was thinking something fully synth 10-40 or should I go something thicker like 50w for summer?
Wow, they do have alot of brands there. How much is their Redline selling?
No idea but judging from their Delvac pricing it wont be cheap. :)
Oh well, I guess I'll have to fork out the money, unless there is something better than Delvac for 70 bucks? :P
No idea but judging from their Delvac pricing it wont be cheap. :dry:
Oh well, I guess I'll have to fork out the money, unless there is something better than Delvac for 70 bucks? :sleep:
Do check with Harold from performancelub.com they do supply Mobil, Royal Purple & some other stuffs.
hey trex and busky2k
I'm getting confused with the diff oil...read stuff about it and thought i was cool...
Castrol Syntrans and Syntrax..75W90 I think they are spec'd at. I have a stock s1 r33. I used Syntrax as it was GL5 rated oil...wondering if I should have used the Syntrans..I get confused with them..Its not for LSDs and I have no idea if I have one or not lol I guess I should know.
KJ
Castrol Syntrax 75W90 - GL4/5 suitable for both diffs and gearboxes.
Castrol Syntrans 75W85 - GL4 for gearboxes only but tends to give better shifting than Syntrax for gearboxes specifying GL4 fluids such as our nissans.
So you chose the right thing!
haha thanks man...it didn't make any noises...so I thought I was cool. Just in the Castrol spec sheet it says not for LSDs...but the stock R33 diff is a viscious LSD and aparently this is still cool...but I'm still not sure about that.
When an oil is spec'd for LSD use, they mean its appropriately friction modified for clutch LSDs. Most of our LSDs are viscous coupling (VLSD) which means they use their own internal fluid for the 'lockup'. So for VLSDs it doesn't matter if the oil is specifically rated for LSD use or not - just so long as its API GL5 rated. So you are safe with Syntrax.
I looked for hours and couldn't find the info. Bascially I had to reasearch VSLDs and how they work and found out exactly what you said...then got confused again! haha thanks for that mate.
hey guys im due for my first oil change since i bought my car.. engine has recently been rebuilt and has been run-in.. was wondering wot oil to use.. have read/heard good things bout redline and royal purple.. shud i also change my transmission oil as well.. if so which oil?
also my friend had tried putting a short shifter into my car a month ago and the plastic thing right at the end of the gearstick came lose and got lost inside.. does this affect anything as i was told it will get munched up.. shud trans oil change be done to try n flush out any bits?
i mainly use the car on weekends and short trips but no track work etc.. also i was interested in getting a tomei baffle kit.. how does it affect the oil or change things for the better??
cheers
nesh
Can someone please confirm if 20/60 is too thick for my r33? When i give it a bit the oil pressure rises to nearly 8. should i drop the oil and put in some thinner oil?
If all else being equal, oil pressure is inversely proportionate to flow rate, the higher the pressure the lower the flow. You are starving your engine of precious oil during startup and before oil temp is up to operation temp.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
