i think Castrol Syntrax is another good alternative for the diff.
Nulon Engine Oil Flush. What are you thoughts on this guys? Worthwhile? Waste of time? Just plain dodgy?
http://www.nulon.com.au/products.php?productId=eof
I believe Martini make a similar product, but damned if i can find the name of it...
I am about to do my first oil change and I thought I would just spend the money (car is about to spend a session on the dyno getting tuned) and get some Motul 300V. Trouble is it only comes in a 4L bottle - is this enough to do a full oil change in an RB25DET Neo? How much oil do they take?
Also I will need a new filter, are the generic Ryco etc. good enough to use? Do Repco and similar stores stock the suitable oil filters for RB25DET's?
Any help is greatly appreciated as I am hoping to pick up the bits tommorrow! :wave:
i can answer this was some first hand experience!
Motul 300V slightly better than Mobil 1 0w40
none-the-less, Mobil 1 is still a very good oil. 0w40 is not too thin, well unless if you have a very old car, or perhaps doing some serious track work. But street driven, Mobil 1 is more than fine ;)
I just did my R34 on saturday, Mobil 1 0w40 (would have gone Motul 300V, but i was doing a rather major service, so next time) and it took 5 quarts. 1 quart = 950ml, roughly. So it took 4.75Litres.
Sorry, but you're going to have to buy another 1L bottle. 5L is about perfect. This was with an oil filter change as well.
I was told to stay clear of Ryco. I used OEM filters on saturday (fuel/air/oil). From Nissan, it was about $11 or $16, can't remember which, but it was cheap. Any dealer will have it in stock as it's not a special "For R34's only" item.
Hope that helps!
Oh, car is running slightly smoother, i'm pretty sure it's quieter as well. The lifters on RB's are usually fairly noisy, but the tapety noise of the lifters has reduced a little. My car seems to be in very good nick the further my mate and i look at it (he's a mechanic). So i don't think i have significant gains to make in terms of 'running better' with a good service. But the Mobil 1 has "smoothed" out the engine somewhat, and has made it quieter as well.
cheers,
daniel
none-the-less, Mobil 1 is still a very good oil. 0w40 is not too thin, well unless if you have a very old car, or perhaps doing some serious track work. But street driven, Mobil 1 is more than fine :nyaanyaa:
Hope that helps!
cheers,
daniel
Thanks for that. I think it is so stupid they sell the 300V oil in 4L containers. I know it's probably to make you buy 2 but it's probably just going to make me choose something else instead. Are you sure you can buy 1L bottles of 300V as well?
i just assumed you could :nyaanyaa: obviously you can't then.
So looks like it's 6L's for you, and just buy a 4L next time and then start the cycle again, 6L, then 4L, etc :nyaanyaa:
I bought 6 quarts of Mobil 1, but have 1 unopened bottle left over, and some of my Redline oils are left over as well.
So yeah, go 6 this time, and just keep the extra for your next service. 5000km's shouldn't take too long. The oil will keep :laugh:
cheers,
daniel
EDIT: there are some real oil gurus in this thread, so hopefully i haven't sent you down the wrong path. But i looked into this a fair bit before my service, and i hope i'm passing on knowledge unblemished as it was given to me :laugh:
i just assumed you could :laugh: obviously you can't then.
So looks like it's 6L's for you, and just buy a 4L next time and then start the cycle again, 6L, then 4L, etc :)
So yeah, go 6 this time, and just keep the extra for your next service. 5000km's shouldn't take too long. The oil will keep :D
cheers,
daniel
EDIT: there are some real oil gurus in this thread, so hopefully i haven't sent you down the wrong path. But i looked into this a fair bit before my service, and i hope i'm passing on knowledge unblemished as it was given to me :)
Thanks for that. I actually ended up buying 5L of Motul 8100 5W40 100% synth instead. Will do the oil change today :)
  • 1 month later...
When i get into the monthly supersprints i will start using mineral oil. penzol or something!
i've been recommended by a well expreienced race engine builder
Don't be silly.
The only reason people occasionally recommend mineral oil is that for reasons partly unknown some synthetic oils do not agree with old fashioned push rod engines. Specifically the cams & cam followers suffer. It is sometimes blamed on the amount of friction modifiers in the synthetics & the large surface areas of the valve train components in push rod V8's.
Old fashioned motors are a world away from your RB whatever. Use a good quality synthetic oil of appropriate viscosity & overfill it if you are going to the track.
lol, andrew, that is one of the funniest things I've read in a while!
Motul Chrono 300V, or the next one up if you are worried.
as for the monthly sprints are you running this sunday at EC? I will be there.
Thanks for that. I actually ended up buying 5L of Motul 8100 5W40 100% synth instead. Will do the oil change today :D
the motul 8100 is ok, but it's not a full synthetic ester oil like the 300V is.
I know bugger all about anything, but I know the chrono 300V is damn good oil. for the money I think it's well worth it. and yeah, you can buy a 4L and a 2l. then next time you just need a single 4l. :)
Actually Baron I have had people knock back offers of a top up of Mobil 1 for their old school (in this case Alfa) motor because they were too scared to put a synthetic oil in it. Believe it or not....
yeah, but he's not driving an alfa! he's using RB26 power. which to me means running a mineral oil is nuts.
depends on the car though, you are right. but we are only talking about one type of car here. ftr we use synthetic in our alfa, but it does have a built motor in it.
stay away from castrol edge and penrite syn 5..... turns to water in rb's.
my 2c's :whistling:
oh yeah pay no attention to the oil test done in street commodores a few months back which royal purplue won.... it was a crock of shite, they used grease testing rigs to test oils... morons.
Edited by URAS
I just had the Motul 300V chrono put in. Engine definately feels smoother. Didn't do much to quieten the tapping sounds though.
What I was most impressed with though was the Red Line light weight Shock Proof gear oil. I would recommend this to anyone with worn syncros and/or gear box notchiness. Think twice before getting a reco box and try this stuff. It's gold! :)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
