LOL so hey can anyone provide sum info on royal purple for skylines??.. or is it like a super hard thing to get outa people :P
You know, i can get better wear reading with head and shoulder shampoo then all these oil tested. The chorine in there are a very good extreme pressure additives, it just that when you include it in your engine oil combine with moisture, you will form hydrochloride acid.
This article from StreetCommodore is very misleading, this Timken test are only good for grease, not oil. The editor has admitted the test is flawed and not representatives of actual engine condition.
StreetCommodore reply:
http://www.streetforce.com.au/news/01_oils_aint_oils.php
I concur. THis has been covered many times. I dont put faith in what someone said when they have no credability.
Hey guys,
been reading the first & last few pages...
I've come to the conclusion that I should go for the mobil 1 0w40 & buy about 5 litres for my car
I have an R34 GT-T with a turbo back exhaust, pod and 60,000K's
Is this a good choice? Still new to the whole D.I.Y service thing
Any info is greatly appreciated guys :rolleyes:
Hey guys,
personally i 'think' the zero wt oils are too light, they recomend from factory 7.5wt... keep in mind our cars are round the 10yr mark so seals do tend to give a little, i would think the 10-30 mobil one would be overall safer.. it might take a little longer to warmup than the zero but... meh
Some castrol and Penrite facts;
The name comes from Castor oil which is ok, they then turned their hand to esters.... and failed giving synthetics thier bad reputation early on in the piece.. they no longer use ester... it is left to oil professionals.
did you know that castrol/Penrite Sin fully synthetics are actually only partial synthetics? the only full synthetics in australia have to say 100% synthetic on the bottle.... stoopid loop hole in consumer law.
Also to achieve a wide spread of 10-60 (penrite too) you need to add alot of additives these additives are not lubricous therefore actually reduce and dilute the amount of lubricant in the oil....
Where do u get that info from?
hehe dont believe me? walk into repco autobarn or supercheap and make a list of all the oils which say 100% synthetic.... you will be suprised you will find 3 or 4 the rest are marketing hype.... you are buying the name or slogan not the oil.
MOBIL 1
MOTUL
NULON (crap though)
REDLINE
Of course there are other boutique brands like AMSOIL etc but they are not available at most outlets.
(URAS @ 13 Jun 2007, 02:04 PM) *
You got to be joking.
Edited by Trex101
MOBIL 1
MOTUL
NULON (crap though)
REDLINE
Trex you seem to know your stuff about oils, is this true?
The other thing, even if Castrol is not 100% synth, I doubt it matters much since most people change their oils 5000-7000 KMs.
How do you define 100% Synthetic? Technically, engine oil consist of 70-80% base oil + 20-30% additives carrier fluid. The oil can be call a Fully Synthetic once the base fluid are 100% group III grade & above. The formulation of modern oil is very complex and can't be judge base purely on base fluid (but of course a group IV or V fluid will be more value than group III). A well formulated oil got to have good base fluid couple with strong anti-wear additives package, one can't just work without the other.
Group I - mineral
Group II/II+ - hydrocrak (VI below 120)
Group III - hydrocrack (VI above 120, mineral derive "Fake Synthetic")
Group IV - polyalphaolefin (man made Synthetic)
Group V - Ester & other un-group fluid (Ester or Polyolester, super high grade Synthetic, good for aircraft jet engine).
Well, to answer your question. In my opinion
MOBIL 1 --- are using group IV base fluid aka Fully Synthetic
MOTUL --- depends on type, the 300V are using group V ester base, race spec fully synthetic.
NULON (crap though) --- don't know about this brand but i doubt it good stuffs since they promote PTFE in their oil additives.
REDLINE - group V Polyolester + very overdose of anti-wear additives, race spec fully synthetic.
Edited by Trex101
Group I - mineral
So what group does my current oil Castrol Edge Sport 5w-30 belong to?
I'm sure its better then any oil that was around when your car was made.
Good point.
I guess Im just being cynical.
I first was using Shell Helix Ultra, got told its not that good. Also Ferrari endorses it quiet a bit and their engines are prone to rebuilding often... might have more to do that they dont get driven that much but still.
Then I moved onto Castrol Edge Sport (improved R formula)... I want to stick with it as its rather good value and prior Ive only read good things about Castrol.
I dont want to really pay above 70 bucks for 5 litres of engine oil since my car never sees the track or hard motoring.
the castrol is a cheap oil. group III base. if you want a good oil you have to pay more for it. it's that simple. the castrol you pay for marketing, motorsport involvement etc, and a bit of your money goes to developing oil, but it's still a cheap oil, and in my view poor value. but again its' a simple equation. good oil costs more than worse oil.
personally I think if you care about your engine and like to give it the old spanking then a IV or a V is the go. I use motul chrono 300V. costs a lot, but to me it's worth every cent. oil is one of the most important ingredients to a happy car. in my mind it's right up there with tyres as the biggest thing people underspend on. I say you can never spend too much $$ on good tyres, or good oil.
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
