Guest RedLineGTR
Originally posted by red17
I am told that only the 0W40 and 10W30 tri synthetics are the only 2 TRUE synthetic oils that Mobil make.
Someone told me recently their brocky ad campaign was pulled because someone got shirty with them in regards to their so called synthetic 5W50 you buy off the shelf at autobarn, NOT being fully synthetic.
But ive also been told bullshit from this person in the past, so I wouldnt put it past him to shovel a little more.
Red17
Can anyone confirm this???
You can buy Amsoil through Autospeed shop. I have read alot of court cases against oil suppliers and oil additive companies like Slick 50. Amsiol were taken to court because they claim to be first in synthetic oil. All oil manufacturers were asked to comment (agree/disagree) on there claim. Not a single one did and the case was dropped.
I have seen another site which claims Mobil 1 is 200% worse than Amsoil.
Elf is a fuel manufacturer; they should know what they're doing. If you go for any sort of synth oil, and you change the oil every 4-5000k's i don't think it is an issue. We should be worried about frequency of change, not so much the oil itself. We can argue till the cows come home about whether mobil/shell/motul/royal purple etc is best, but at the end of the day any of their synths will protect your engine regardless of how hard you drive it.
  • 1 month later...
Hey guys, i was looking on the Amsoil website and it says that their 10-40 oil is:
In gasoline-fueled passenger vehicles in normal or severe service, change AMSOIL XL-7500 Synthetic Motor Oils at 7,500-mile or six-month intervals, whichever comes first.
Shit - thats a long time. I guess that is pretty good compared to the other oils that have been thrown around in this thread.
http://www.amsoil.com/products/xl7500.html
  • 4 months later...
Just for anyone that thinks Motul is the be-all and end-all of engine oils - When my lifter blocked up and started rattling, I was running Motul oil. Now, I'm not specifically blaming this oil for causing the blockage, but people have a tendency to blame whatever oil they're running at the time for whatever engine problems occur, especially with blockage of the galleries etc.
I don't know if the Motul oil caused my problem, but with the last oil change I have also noticed for the first time the lines going to my catch can starting to stain with blow-by, as well as oil stains on my rear bar near the exhaust. This could just be a coincidence, maybe my engine is just naturally starting to wear at this point in time and I just happened to be using Motul oil while it happened. But I am going to change brands to see if it makes any improvement.
I have also had no problems using Motul oil on my motorcycle. I think I will switch back to it because it's cheaper than the Castrol I'm currently using in it. Or I might try Mobil.
I had valvoline 15W-50 synth in my GTR and just changed to mobil 1 5w-50 synth and it feels as though the car revs alot easier....probably because of the thinker oil...I noticed some of u guys don't like Mobil 1...any particular reasons?
  • 5 months later...
When I first got oil for my GTR32 I used Penrite, but found that Motul synthetic oil was a bit cheaper and way better. Oil px is good esp on start up and engine seems to be a little quieter esp when cold.
Best to get the viscosity that nissan recommend because the RB engine are built to close tolerances and I wouldn't want to put in something too thin or too thick.
  • 6 months later...
i use vegetable oil (crisco) not! hehehe
im still deciding on which oil is best the above responses are excellent in muy oil hunting process.
have tried Mobile 1 synthetic on my old turbor lancer/honda vtec and loves it so much but burnt it so quick.
might try Motul but so expensive?
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
