Further to the comment about gulf 1 being a track oil. Can I ask why you say that? I'm not saying thats not correct but I want to know why you say it as the rep suggested I use gulf 1 now that sougi 6000 is gone.
Suigi S6000 is 10w40.
Gulf 1 is 10w60.
10w60 is great.... for tired engines with poor tolerances and/or serious blowby problems. Not something you would want to put in a RB which has 7.5w30 specified by factory (10w40 taking into fact our warmer climate).
The 60 rating is nice and thick for track duty, though if the engine isn't built for it (ie. no sump mods or extensions, head restrictorss), the thickness of the oil will have trouble draining back to the sump and the engine will end up with oil starvation.
I just did an oil change after running Penrite Everyday full-synt 10W-40 for the last 2,500kms. Car had 102,500kms when I put that oil in, and now I just gave it some Motul 8100 x-cess 5W-40.
To be honest, I thought Penrite did a good job, but decided to try something different. Penrite oil was completely black after 2500 kms, so now I'll check if Motul looks the same after similar number of kms. Car did not use any oil during this period which is a good start. I'll also check for this really heavy burnt smell I had with Penrite from the start, it just smelled like it was burning, but some people on this forum said that this smell and blackness of oil is normal - lets wait and see how Motul goes.
quick question if i replace the pistons ,rings and bearings in the motor and valve springs etc what oil should i use after run in the reason i ask is i notice that people talk about older rb's etc with bigger tolerences and things and use a different type of oil eg. 5-60 grade i was planning on using a 10-40 Ur help would be appreciated
^ I'd rather my oil have all the black crap than the contacting surfaces inside my motor. What oil did you use before your change?
I'm about to start my maintenance regime on my newly acquired, fairly stock 34Gt-t. Kicking off with it's 100k service. I'm thinking of using Royal Purple 10w40 for my first stint, after a flush with a cheapy. But I have also been considering Motul 4100. Decisions decisions!
My mate ran RP in his 34 and had nothing but good things to say, plus you read the odd thing here and there. Not too many negative things are said about RP, if at all. But if anyone wants to suggest to me otherwise, go ahead!
yeah I agree with the royal purple going black really fast (though it is purple to start with...). I've mainly run it in my RX7 as that's what was reccomended but I didn't rate it that high.
much prefer the motul chrono 300v 10W40 for all my road going nissans (currently 2 GTRs and my silvia).
It's probably been asked and answered already but reading through all 108 pages is crazy! Anyway, I was just wondering what the best oil for an N/A R34 25GT (with the NEO RB25DE engine) is? A lot of people have recommended different oils and I'm just not sure which one to go for.
Thanks a lot.
Different additives are used to achieve the 10w40, other than that they're probably both quite similar, aimed at similar markets.
Were they going to scrap the 8100 xcess? I thought the xmax was released as just another product, not a replacement.
Edited by Galois
5w40 is thinner when cold than 10w40
also 5w40 has more additives than other motul oils and in the 300v format is the only viscosity that is not able to be mixed and matched
tuned the car on castrol edge 10w60 the other day...
so far the car idles perfectly, warm's up and runs perfectly at operating temp, and has no signs of negatives with the 60 weight or robbing of any power
car made 290rwkw on 20 psi (old motor made just over 280 on turbolight 10w40)
That's very interesting, how does the tune depend on the oil? Like what are the changes in tune for different oils?
Also what did you mean by the 300v mixing, as in it can't be mixed with other oils? Or other 300v's?
Edited by Galois
Black oil is what you should be dropping and shows that it it cleaning carbon from the engine.
Burning smell is NOT normal and is a sign of an oil that is not up to the task for your engine.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
