Stay tuned Sougi fans...have just got way of the replacement oil, which is due out in a few months. I have no idea if it will be a group 5 or not, but it will be a full synthetic 10w40 known as Syn-X 6000. Will definitely be testing in my car upon release.
I will post more as I find out, and hopefully give you an idea of the retail price we'll be looking at.
Good stuff! Shoud have enough s6000 to see me through till it comes out!
hey guys seeing tho s6000 is not available would the m5000 be ok to run for a while til the syn x 6000 is released
Why wouldn't it be okay?
Mate, even the wrong oil isn't going to kill your engine as if it's poison. But for the record M5000 is merely the semi synthetic version of S6000.
You could put big w spec 25w 50 $5 for 5L oil in there and it would be fine, won't last long and if you are tracking it won't be optimal, but it won't do any harm.
About 20-30 bottles from memory.
yeah after doing alot of research on this i have worked out that it wont do harm i just wanted to find the most optimal oil for a rb25det
There is no such thing...every engine is different.
There are only oils and better oils. Experiment, find out what you prefer, both in viscosity and brand. Most people here are happy with 10w40 in various brands.
Interesting thread..
Just a couple of thoughts,
The DIY oil industry is a trillion dollar market, and most of the advertising claims reflect the grab for market share.
Ultra low viscosity oils (0w/20, 5w/30 etc) were developed for below freezing starts and increased mileage benefits..and not extended engine longevity.
Running these oils at startup in moderate/warm climates means your running oil the consistancy of machine oil at a time when clearances haven't stabilised and lubrication is minimal.
Your engines lubricating system, oil pump and bearing clearances were not designed to run such oils.
In this country SAE recomends 10w/30 and 10w/40, like most manufacturers do for 90's vehicles, for ambient temps in most areas. better to stick with that range in a quality oil.
Oil viscosity ratings, and tests are conducted on clean oil stocks in a lab environment, and don't reflect oil thats been running in your engine for the last 2 months or more.
Using Delvac or any diesel oil will cause oil leaks in any mid to high mileage engine, as they contain a very high level of detergents.
Synthetic oils become contaminated just the same as dino oils do, with combustion by-products, blow-by, fuel contamination and condensation. Using extended change intervals means running contaminated oil for longer periods.
Running expensive syn racing oils for OEM recomended change intervals can be very expensive, and probably has a very limited benefit.
Filters are as important as the oil your using, maybe even more so, if you choose the wrong one.
There's no substitute for oil film strength in a perf engine, so viscosity should match the upper level recomended in the SAE range for the appropriate ambient temperature.
When it comes to recomended viscosities, who are you going to trust..the manufacturer (who pays for warranty claims) the oil companies? or the guy at the store.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
