Google "Fumoto" oil drain valve if you haven't heard of it...
Installed one of these on my R33 a while ago and not only does it make oil changes as easy as flicking a switch (no more sump plugs and washers and oil pouring out over your hands/spanner), it looks kind of cool too :)
Very cheap for what it is!
The k&n with the nut, what a brilliant idea! Why don't they all do that...
well considering filter is only meant to be hand tight I would think its pretty pointless just like changing your sump plug washer..dont overtighten things in the first place and you wont have any problems :thumbsup:
Thanks for the advice Rolls, I think I'll go the cheaper option Motul, does seem to make sense when you put it in the new motor perspective.
Now... Where do I get my hands on it? Supercheap doesn't stock Motul right? I'm in Sydney.
Where do I get a Nissan oil filter?
if your after motul 4100 turbolight check out just jap in the traders section... bought 5L for 80 odd bucks including postage which only took a day
I use one of these,just like you said makes oil changes a breeze. :yes:
It definitely looks good. How secure is it though birds, I'm guessing you've never had any trouble? Does it feel like the safety latch will protect against a wayward stone flying up under the car?
I've only ever done filters up hand tight and only ever managed to undo one or two by hand (of a couple of dozen changes at least). Having that leverage/grip makes it so much easier. Though you can always just stick a screw driver through it (never done it myself but have been tempted).
Isn't 4100 turbolight usually a fair bit cheaper than that? Seeing as 8100 is usually $75-80?
yeah it was like 60 bucks for 5L postage was $20 ish.... lol the screwdriver trick... i thoroughly dont recommend it - some say its ok - for me an oil change usually takes an hour.. it took days to finally wrench my old filter off after breaking just about every tool i had
Doesn't sound right, 8100 xcess is only $60 when you shop around, 4100 is cheaper again. Worst case 8100 is $80, 4100 should never be that price.
well I would think that means your doing them up to tight wouldnt u?
Also are you putting them on dry or wet, smear a little oil around the seal and half fill it with oil before you put it on..
Anyway, I guess some people just dont get it, which is why they make filters with little nuts..
i dont see why anyone would use a semi synth 4100 when you can get a full synth 8100 for about the same price .. is it because its called turbolight people think its better for turbos :unsure:
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
