Google "Fumoto" oil drain valve if you haven't heard of it...
Installed one of these on my R33 a while ago and not only does it make oil changes as easy as flicking a switch (no more sump plugs and washers and oil pouring out over your hands/spanner), it looks kind of cool too :)
Very cheap for what it is!
The k&n with the nut, what a brilliant idea! Why don't they all do that...
well considering filter is only meant to be hand tight I would think its pretty pointless just like changing your sump plug washer..dont overtighten things in the first place and you wont have any problems :thumbsup:
Thanks for the advice Rolls, I think I'll go the cheaper option Motul, does seem to make sense when you put it in the new motor perspective.
Now... Where do I get my hands on it? Supercheap doesn't stock Motul right? I'm in Sydney.
Where do I get a Nissan oil filter?
if your after motul 4100 turbolight check out just jap in the traders section... bought 5L for 80 odd bucks including postage which only took a day
I use one of these,just like you said makes oil changes a breeze. :yes:
It definitely looks good. How secure is it though birds, I'm guessing you've never had any trouble? Does it feel like the safety latch will protect against a wayward stone flying up under the car?
I've only ever done filters up hand tight and only ever managed to undo one or two by hand (of a couple of dozen changes at least). Having that leverage/grip makes it so much easier. Though you can always just stick a screw driver through it (never done it myself but have been tempted).
Isn't 4100 turbolight usually a fair bit cheaper than that? Seeing as 8100 is usually $75-80?
yeah it was like 60 bucks for 5L postage was $20 ish.... lol the screwdriver trick... i thoroughly dont recommend it - some say its ok - for me an oil change usually takes an hour.. it took days to finally wrench my old filter off after breaking just about every tool i had
Doesn't sound right, 8100 xcess is only $60 when you shop around, 4100 is cheaper again. Worst case 8100 is $80, 4100 should never be that price.
well I would think that means your doing them up to tight wouldnt u?
Also are you putting them on dry or wet, smear a little oil around the seal and half fill it with oil before you put it on..
Anyway, I guess some people just dont get it, which is why they make filters with little nuts..
i dont see why anyone would use a semi synth 4100 when you can get a full synth 8100 for about the same price .. is it because its called turbolight people think its better for turbos :unsure:
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
