Oh noes, I must have spun heaps of bearings by now then. I have been using Gulf Western products for 3 years now with hundreds of dyno runs and track work.
Considering 10 w 40 is thicker than the factory recommended I am sure it will be perfectly fine. The same can't be said for a w 60 like edge unless you live on a racetrack, and it won't save your bearings.
But oh noes, you blew an engine and you were running GW so it must be shit....
also, head gasket performance is now related to oil quality
They will have gulf western on their shelves in the next 2 or 3 weeks i was told.
I contacted gulf western directly.
They're very helpful. You can pick it up from them in Penrith NSW.
edit:
Just to add - a few days into it now, a few WOT squirts, cold starts, warm traffic idling, and general all round use, and I'm loving this oil.
If it performs till the next oil change (and from all reports, it should easily handle my standard 5000km intervals), i'm a happy camper.
Edited by Munkyb0y
Enough of this bitching. I want gukf western syn x 6000 Repco and autobarns only have 3000 Anyone have a good online source for this?
imo synx 3000 is heaps good if you're changing at 5000km.
and your car is stock.
but your car isnt. so good luck on finding 6000
Edited by xALmoN
3-4 years unopened i think, and if you're storing them in a cool dark place, even when the seal has been broken, it shouldn't matter that much, since its all pumped into a bottle from the storage tank anyway, no vacuum sealing and things like that, just the cap and seal.
edit:
Syn X 6000 will last you to 10,000km if you really want it to. If it's a daily driver and you don't thrash your car everytime you go out, then you can draw a full synthetic out to 10. I am like you though, in that I like my 5,000km intervals. By then the old RB has made any decent oil very black!
It is a very good oil, I ran it for 5,000km during my last interval. For those who don't want to fork out for 6000, there is 3000, which will do just as good a job.
Yes, thicker oils create a thicker/stronger film between moving parts...the oil has to get in and out of there in the first place, though. Thinner oils are generally better at circulating an engine with tight tolerances and servicing an overhead valve train. The key is striking a balance between the two!
Most engine wear happens during cold start up and cool down - 10w60 and 10w30 are the same thickness on start up, so out the window with a lot of theories about viscosity choice being responsible for engine failure. I've said it many times before: you can't really go wrong with viscosity choice...there are only suitable and more suitable grades. More important are regular oil changes and that it comes out filthy black!
Speaking of filthy and black....
The inside of my motor is that but the oil is still clean
So thinking a mild detergent diesel oil to clean it
Anyone reccomend a diesel oil for a turbo petrol engine?
Planning to change it out after <1000ks
Unless your engine has been rebuilt recently, the filth isn't necessarily a bad thing...it is now one with the engine and probably keeping things nice and quiet :thumbsup:
All RBs are dirty engines, they produce a hell of a lot of carbon, which is why the better oils come out pitch black after only a few thousand...so I wouldn't stress over it. Unless you have engine issues, the only cleaning you need to do on the inside is to use a decent petrol oil. The GW petrol oil products are fairly detergent heavy, so maybe whack some Syn X 3000 in there and it'll do all the cleaning you need.
For the record, any diesel oil with an SH/SL/SM rating appearing after the diesel rating will work in a petrol engine.
Shell Rotella T6 & Mobil Delvac 1 both in 5w-40 provide very good additive packs and are run in several petrol applications with good UOA results over on BITOG
difference between the 2 primarily is Delvac 1 is a group IV PAO based synthetic & Rotella is a Group III Dino - if you're running it only for a short amout of time the Rotella will be fine
I'm currently using Delvac 1 in my Forester EJ255 Turbo (wrx motor) after the great results posted up on BITOG
Rotella can be bought here
http://stores.ebay.c...u/GL-Lubricants
Delvac 1 available here
http://lubesdirect.com.au/
Edited by squareznboxez
    • I'd want an even MORE side on view. More or less you want to make sure the outlet is actually square with the outermost part of the bumper. Or you end up getting soot all over your bumper from your hektik exhaust. In any case, it looks pretty close. I think the way to fix this is probably more of an overhaul at an exhaust specialty shop if you want tips that are rounded off or sit nicely with the bumper but have proper clearance and don't move - Probably more of a redesign than a quick fix. I've pencilled in my own exhaust with its own various problems, pinholes, PITA fitment, and other issues and can see myself going to a shop and saying "JUST DO THIS BUT BETTER?"  Which is gonna work better than any more small fixes. I'm gonna chime in here officially with "from an outsider perspective this exhaust looks fine so this is self OCD probably" (which I also suffer from)
    • Reminds me I really need to install that HKS oil cooler I bought years ago.
    • It be 40°C outside lately. 10W60 is a good idea here. Well, certainly 10W50.
    • Here are some side on's.
    • I just did an oil change on my daily which used oil that is probably 2-3 years old. Normally I try to follow exact viscosities, but my LS400 is fairly tolerant. Dumped something like half a quart of 0W30 Mobil1 ESP X2 in there, followed by 2 quarts Pennzoil 5W30, followed by ~1.2 quarts of liquimoly 5W30 LL04 spec oil. Then the rest was QS euro 5W40 which is actually so thin it's basically a 30 weight oil. All this is to say it doesn't matter that much. We aren't talking about brake fluid. For an RB I would recommend a high ZDDP oil because it doesn't use rollers in the interface between the cam and valve, but a 5W30 or 5W40 is fine to use for street use. The 10W60 guidance really only applies if you're getting it hot and pushing the engine hard.
