Generally, unless you're radically changing oil viscosity or the old oil is very old/dirty, you're usually fine to just get the oil up to temp, drop it (don't burn yourself) and throw a new filter on with some fresh oil of your choosing.
Thanks for that, thinking of going penrite HPR 5w-40 full synth. Or the everyday+ 5w-40 semi-synth. Edited by Zrobe
Could all be placebo but...
Going from Motul 8100 xcess 5w/40 to Gulf Western Synx 5w/40.
The motor feels a little more..."lethargic" during initial start, like it won't rev up as freely/easily/quickly.
Could just be the weather....
I checked out the spec sheets of both Motul 8100 xcess and Gulf Westerns Synx6000, both were very similar on paper. even the Penrite HPR 5 is similar....
Could be just the cold weather...or there is something different between them that isn't counted on paper.
  • 4 weeks later...
hmmm.
missus mazda 3.
was using penrite everyday syn 5w40.
engine has approx 130k.
went to motul 8100xcess.
feels alot quicker and more responsive.
might be the oil.
I use the cheap $22 GW Synx-3000 semi-syn oil in my car & doesn't notice anything compared to what ever stuff was put in there by the work shop before.
I changed it every 5k km or 6 month & the car (used) to be a daily driver (no tracks) so I don't see the point of spending >$40 for oil.
I've come to the same conclusion too, when you work out what you save over a 100k km on the $70 oil it adds up to nearly the cost of a low K wrecker motor.
Have read the last few pages of the thread but to be honest it's a bit all over the place. Just wanting to know what brand/weight of oil to use in my car.
RB25DET Neo with 130xxx k's on it. Will be my daily but I will hopefully be doing a few track days and 6-7 drift days per year and I will be driving it fairly hard. Where I currently am the temperature he's down to about 0 overnight and about 20 during the day.
Not really sure what brands are good and what weights for climate/engine age so any info would be handy, thanks!
What brands would you suggest? Or doesn't really matter as long as its fully synthetic?
This engine won't have been started in about a year either, am I best off buying some helper stuff to put in at first start up then changing the oil once I know it's running fine?
Been digging through this thread quite extensively but still having trouble making up my mind, hence my current post.
Just wanted some opinions on what oil i should be using for my next service. This will actually be my first service since owning the car so i don't wanna skip out on anything. I'm willing to spend big $$$ to make sure my pride and joy is running at its best. Through my reading, i've come across some good rep for SYN-X 3000, Mobil 1, Motul and Royal Purple.
CAR DETAILS
'98 Skyline R34 25GT (Coupe)
Automatic
Approx. 93,000km
Never tracked
It's been recommended to me, based on the number of kms the car has done, that i should be going for something along the lines of... Fully synthetic 10W-40.
Any info would be appreciated,
Cheers
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
