Generally, unless you're radically changing oil viscosity or the old oil is very old/dirty, you're usually fine to just get the oil up to temp, drop it (don't burn yourself) and throw a new filter on with some fresh oil of your choosing.
Thanks for that, thinking of going penrite HPR 5w-40 full synth. Or the everyday+ 5w-40 semi-synth. Edited by Zrobe
Could all be placebo but...
Going from Motul 8100 xcess 5w/40 to Gulf Western Synx 5w/40.
The motor feels a little more..."lethargic" during initial start, like it won't rev up as freely/easily/quickly.
Could just be the weather....
I checked out the spec sheets of both Motul 8100 xcess and Gulf Westerns Synx6000, both were very similar on paper. even the Penrite HPR 5 is similar....
Could be just the cold weather...or there is something different between them that isn't counted on paper.
  • 4 weeks later...
hmmm.
missus mazda 3.
was using penrite everyday syn 5w40.
engine has approx 130k.
went to motul 8100xcess.
feels alot quicker and more responsive.
might be the oil.
I use the cheap $22 GW Synx-3000 semi-syn oil in my car & doesn't notice anything compared to what ever stuff was put in there by the work shop before.
I changed it every 5k km or 6 month & the car (used) to be a daily driver (no tracks) so I don't see the point of spending >$40 for oil.
I've come to the same conclusion too, when you work out what you save over a 100k km on the $70 oil it adds up to nearly the cost of a low K wrecker motor.
Have read the last few pages of the thread but to be honest it's a bit all over the place. Just wanting to know what brand/weight of oil to use in my car.
RB25DET Neo with 130xxx k's on it. Will be my daily but I will hopefully be doing a few track days and 6-7 drift days per year and I will be driving it fairly hard. Where I currently am the temperature he's down to about 0 overnight and about 20 during the day.
Not really sure what brands are good and what weights for climate/engine age so any info would be handy, thanks!
What brands would you suggest? Or doesn't really matter as long as its fully synthetic?
This engine won't have been started in about a year either, am I best off buying some helper stuff to put in at first start up then changing the oil once I know it's running fine?
Been digging through this thread quite extensively but still having trouble making up my mind, hence my current post.
Just wanted some opinions on what oil i should be using for my next service. This will actually be my first service since owning the car so i don't wanna skip out on anything. I'm willing to spend big $$$ to make sure my pride and joy is running at its best. Through my reading, i've come across some good rep for SYN-X 3000, Mobil 1, Motul and Royal Purple.
CAR DETAILS
'98 Skyline R34 25GT (Coupe)
Automatic
Approx. 93,000km
Never tracked
It's been recommended to me, based on the number of kms the car has done, that i should be going for something along the lines of... Fully synthetic 10W-40.
Any info would be appreciated,
Cheers
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
