I was using Motul xcess 5w-40 before i tried the gulf, basically in a nutshell.
Pressure would build up quicker with the motul oil
The gulf western made the car feel "lethargic", almost like it was slower to rev up
Otherwise that was it, it just felt different to drive....I mean I could be crazy and it could all be placebo, but there was definitely a difference in the way the car revved.
Ill see how i go with the Shell Helix Ultra 5w-40.
It's a different grade, of course it would feel different. How often would it be at hot oil temps this time of year...
Do you have an oil temp gauge?
Pouring new 10w40 into an engine today it was like honey...
Well both grades were rated the same, 5w-40 - is that what you are referring too scott?
The R33 GTR has the stock oil temp gauge, once the oil gets up to temp, it seemed to feel the same as the motul (100degree's). Just at lower temps it felt like i described. Where the motul was different at lower temps.
Its been a while since I had the motul in it, so looking forward to seeing how the Shell stacks up against the two, as its priced somewhat in between them both.
Sorry Booki, I just checked and you are correct, the GW synx 6000 is indeed 5W40, I checked the old Sougi 6000 accidentally which is a 10w40 and the Synx 3000 which is also a 10w40.
I haven't had any issues with any of these grades feeling lethargic, although I suspect the VQ's run a higher oil temp as standard.
agreed.
see my previous post regarding motul vs penrite.
Penrite make it clear on their website that the '10 Tenths Racing 10 (10W-40)' is a synthetic mixed of group 4 and 5 which is great, but my local doesn't stock it!
So I've got to settle for the HPR 10 (10W-50). I've tried searching this thread but can't find an answer as to what group Penrite HPR is.
Anyone know?
Anyone know?
i bought some at supercheap last time....
i really want to find a drum of it or a place that can fill a supplied drum/container, any clues?
Edited by Dan_J
I bought some Penrite Enviro+ 5W40 to try next change, full synth and SN rated so it should be fine with ethanol. 10 Tenths is hard to find.
Really most autobahns stock it regularly. I swapped from 10 tenths to royal purple and found it ran pretty well in the 33.
Anyone know?
There is also Premium 5 (5W-60)
If you local store doesn't have it, go to another one (if you can).
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
