yeah that's it, Liqui-Moly, looks like a good product, its nice and light, the engine feels more responsive so will see how it goes.
Did you have a 10W-40 in there before or something heavier? Generally lighter oils should make a tiny bit more power and be a tiny bit more fuel efficient.
yeah I had some Castrol edge 10-60w, it has a bad lifter problem so I tried many flushes and oil changes and still there so ill have to replace them,
Also I might add, if anyones using flushes just be careful, cause after using 2 engine flushes, it seems the engine has picked up some noises, more noticeable is piston slap, probably cleaned carbon from the top of the pistons :(
Don't judge an oil by its colour. You can't draw any conclusions from colour. For example. oil that looks black after use may just be doing a good job of cleaning the motor's insides.
Agree with caveats. New oil colour doesn't mean anything you're just looking at the colouring they added in the factory in many cases (additive mix and stuff).
Old oil colour is an indicator of how many particulates the oil has managed to trap. In this situation dark brown oil is a good thing, because the oil has taken the contaminants and trapped them in suspension. If an oil is really black then your change interval is too long or you have switched to an oil with more detergents in it and it has dissolved deposits that your last oil was inadequate in clearing away. Honey coloured oil means it is not doing its job well, assuming you are burning petrol. LPG/E85 doesn't produce any soot so oil will still look honey coloured even when it has reached the end of its service life. This is bad because the oil is not lubricating properly even though it looks new.
You can draw conclusions from colour of used oil but only if you know what colour it started out, how long it's been in the engine and what fuel the engine has been burning. Without that information it's useless.
that's blows my thinking away, I used to use Mobil 1 0-40w, $100/bottle, that was clear going in and only went to a honey colour after 5000k's on 98,
It did change colour after one dyno session, must of been a long session cause it was very dark colour that time, maybe the car just doesn't get flogged enough for it to change colour
  • 1 month later...
Hi guys. I've been using HPR 10 in my daily RB25DET and would like to replace it this time around with probably a Mobile 1 5-50, keen to see how a slightly more premium oil goes. My engine's just about to tick over 200,000km, would it be wise to stick to 10w or can I go for a 5w or even 0w without sacrificing protection? I've been trying to learn from people's experiences on different oil weights in higher k's engines, but info is really mixed overall. I've seen comments saying don't touch lower viscosities if your engine has high k's, and other people saying it's fine. So, what's the go?
That M1 is 17.5 at 100DegC and the Penrite is 19.6 at 100DegC, so yeah the Mobil is a bit thinner. Pretty unlikely you'll feel it with the butt dyno, but if the oils are around the same price, sure, give it a go.
If the engine still runs well, has good oil pressure and doesn't consume oil i'd try a 40 and see how it goes. Keep an eye on the dipstick to see if it starts using. Often the first fill after you change oils is not a good indicator and you should try at least two fills to see how it settles down.
FWIW I run Mobil 1 0W-40 in my cars, but might switch to Nulon to support the local product. Nulon 10W-40 is one of the thicker 40s, so you could try that.
  • 3 weeks later...
  • 1 month later...
="booba32" post="7519451" timestamp="1429511959"]
Just after some advice, i have a 94 r32 gtr as my daily atm, with roughly 100,000kms
What oil do you recommend and what grade should i be leaning towards? cheers.
This whole thread and you still have no idea?
After 158 pages of discussion the jury is out. The best course of action is to just not drive your skyline until further discussion can figure out what oil is best to use!
  • Like 1
I made the switch to liquimoly 10w40 super about 1500kms ago and the oil is already BLACK as. Anyone using the liquimoly stuff and does this mean I should flush it out (prev oil was just a shell semi synth, so thinking the liquimoly is cleaning much better).
    • LS is a good motor, but it hurts my soul when I see it in a RB. Guess it fixes the oiling issues lol.
    • I'm confused. Does this qualify as "Gregging" or are you somehow avoiding the Gregging?
    • More assembly going on, with all sorts of "bolt right on bro" scenarios going on here. Smartly, PTV clearance was checked. And I say smartly because it turns out that the intake was 0.009" from piston meeting valve. This is 0.23mm. This is very not okay. A fast meeting was facilitated between engine builder in Australia and engine builder in the USA which was actually incredibly helpful and constructive actually, various ideas thrown around to get around this issue including: 1) Retard the cam timing which would have brought the exhaust valve closer to meeting piston (it was 0.065") which was uncomfortably close to begin with, and change the cam profile making it 'laggier' 2) Much larger head gaskets which would reduce compression, but half the point of this was to increase compression. 3) New set of pistons ($$$$$$$$$$$$$$$$$) 4) All of the above 5) Get ghetto The concept is you get sticky sandpaper and stick it back to a valve, slightly larger than the valve you/I'm using, like say from a LS3/rectangle port head. You now have a very super advanced flycutting tool to modify your pistons in your block. Then you install it in your head, and attach the other end of the head to a drill. Then you just replicate your valve smashing into a piston with your spinning drill.   This is the result. Repeat many times. It is strongly recommended you have some kind of fixed stop when doing this for extremely obvious reasons because if you press too hard then you're well into apocalyptic repercussion land. The minimum clearance on the intake valve is now 0.075" this is still in the "Too close to be really comfortable" and into "It should be fine" land. Supposedly in the real world the clearances will be slightly bigger. Guess this is what happens when people push envelopes for N/A engines instead of adding boost! Time to move onto the new, upgraded, higher ratio roller rockers from Yellaterra, all tapped and threaded with a stronger bolt for better stability. Very nice. Lets see how they fit. For f**ks sake. Time to bring the grinder out for these aftermarket, machined and CNC'd heads. Looks like the new, beefier rocker from YellaTerra has gone from Bolt on part to "Bolt on part". Well, lets see how this bolt on crank scraper and windage tray goes then, shall we? There actually is more clearance than they specify for this thing, but seeing it all move as you check it is terrifying when you see it all so very very very very nearly hit things. But after all, this is what the item is designed to do after all and actually did bolt on perfectly and have enough clearance to everything and some very clear and direct instructions. So +1 to Improved Racing I suppose. As above with the windage tray on. Photo of breaker bar wonkiness for added lols. Next up: Oil pump/front cover/water pump/sump and then it's time to actually install the heads, pushrods, head bolts, valve cover gaskets and such is all there and ready to go. (except the oil pump bolts which were previously longer for more clearance with the previously perfectly installed double row timing chain). There's definitely a sense that someone other than us has been here before and done everything perfectly, or at least considered it and came up with working solutions. Perhaps the previous cam was 6deg advanced to avoid PTV issues with the milled stock heads? In any case when I attempt to sell this stuff the buyers are going to be very directly informed.
    • my catch can is pretty easy to empty but it overflows due to the blowby/crank case pressure etc. max I have drained is ~600ml even with a ~2.3L capacity. So it is not just about having to drain it out its the mess it makes down the firewall and under the car and rear passenger tyre from the overflow oil being blasted by screamer + air in general. Ending up on the ground cleaning the oil up and having oil on your arms when everyone else can chill and watch the other sessions gets old fast
    • Yeah - the secret learned a long time ago is that the RB likes to belch oil out the covers, and/or starve the pump because it drowns the head in oil, because the upflow of crankcase gases from piston blowby comes up through the oil drain holes in the block and prevents the oil from flowing back down. The external vents from sump are about creating an alternative path/much more XS area for gas flow to decrease the gas velocity up through the oil drains and allow the oil to get back down. So, it's not about pressure at all. It is about flows - gas up and oil down - or when it's not working, gas up and oil not going where it is supposed to after it arrives at the top, except out through the cam cover vents. And regardless of whether the catch can is vented to air or vented to the turbo inlet, it must still be vented because a sealed system would blow out the crank seals, or something equally bad.
