That 10-40 everyday Shiite has been out for a while. Used it a couple of times in an sr20, seemed OK. I ended up changing to castrol edge 10-60 to try and stop my flogged sr from making its ugly sr noises. I don't have an sr anymore. I'm now an rb fan. I've got about 15 litres of 10-60 stockpiled in my shed. I'm wondering if it will be OK to run in the rb25?
that penrite extra10 shite confuses the crap outta me. is it a 10w30 or a 10w40?? package says may be used where 10w-30 is recommended.
everyday 10w-40 made the v35 sump seal weep oil, was all wet. switched to nulon 10w40, dry as... so does that mean penrite everyday is really a 10w30 with some extra "protection'?
Yep diesel engine oils usually contain higher levels of dispersants to prevent the soot particles from agglomerating.
Historically they have always contained higher zinc which has significant anti-wear properties. They got rid of zinc in the 80s because of catalytic converter contamination fears but recently started to reintroduce it into petrol engine oils.
I have used it since 2007 in my LS2 and for 5 years in my RB.
When I blew my turbo couple of years ago I pulled the sump off and it was amazing. No deposits at all.
This is a link to the post with picture of my bottom end after 30000 km of abuse.
http://www.sau.com.au/forums/index.php?/topic/22458-The-Goods-On-Oils#entry7381708
Edited by XGTRX
Technically, yes. It acts like a 30 weight oil.
If you put R32 GTR into Penrites recommendation guide, is says that HPR 5 SAE 5W-40 is the preferred one. The new, cheaper one may be a lesser oil.
It's just for my daily and the mrs car so all good. I use Castrol 10-60 in the GTR.
10w40 and 20w50 full syn oils should have everyone's bases covered,
I have no idea why anyone would want to use heavier oils in a high revving motor like an RB?
unless I had no oil cooler and I was bashing through a Dakar rally then maybe I would use a 60 weight
I use the the Penrite Racing 5 (5W-30) when I can find it on special, but most of the time I'll use the HPR Diesel 5 (5W-40) I have the Racing 5 in there now and it seems spin up a little quicker than the Diesel 5 that it replaced.
Will be interesting to see how the thinner stuff hold up during this summer.
  • 4 weeks later...
Repco has nulon 1040 in 6ltrs for 50 bucks absolute bargain,been using this for hundreds of thousand ks fantastic stuff,no lifter noise on start up and lasts for 10000 ks my ol 33 loves it.:-) :-)
  • Like 2
  • 3 weeks later...
Great sticky, did a bit of research and just bought royal purple 10w40 high performance Street for 92 bucks for 5 litres and nissan oem filter for 20. Will hit 5k service on the weekend. Car currently runs smoothly but would like to see the difference at the high end of things after the change.
I'm Betting none.
  • 3 weeks later...
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
