standard nissan filter will do the job great.
I use Cooper filters that the local parts store keeps in stock. I once read a comparison of "3rd party" filter brands that the Cooper filter did a bloody good job. See here:
http://www.aus-cartalk.com/auspoc/techstuff.htm
Remember that the manufacturer filters are usually just other brands with the car maker's name stamped on it instead. So you're relying on your car manufacturer to specify a filter that does a satisfactory job (comes down to a trust thing really!).
The cooper filter base plate looks just like my Nippon Micro base plate. I wonder if they are from the same manufacturer but different brand?
Mobil is a true PAO synthetic oil with added esters. Contains good levels of detergent and anti wear addatives.
Motormates also do the Purolator oil filters.
Mobil 1 does not have any esters :unsure: They use alkylated naphalines in its place now. Purolator Pure 1s are damn good filters for the money. I'd rather pay for a Pure One than get a free Ryco.
Links, the 8100 is a good oil. But if you can get the Mobil 1 0W40 at a similar price, then get it because it is superior.
I disagree. Ran Mobil 1 in the pulsar and it went off very quickly, and before the service interval. It went from the high mark and light brown to the low mark and dark brown in the space of 2 weeks and an old pac run. My service interval was 5000km which should be very very conservative on a stock SSS.
Motul 8100 never used a drop on my RB20 over 5000km and came out still looking great.
I dislike oils that go off that quickly. Castrol Synth-R was also low on the dipstick after only 4000km on my RB20.
Stick with the Motul 8100. You can't go wrong.
An oil that goes dark is cleaning and suspending crap better than an oil that doesn't.
I'd much prefer my oil to go dark than stay light.
If its using oil... Then for the given motor its too thin, castrol 5w30 is too thin for my rb30det as it uses around 500-1000mls per 5000kms. throw a 40 weight in it and it doesn't use a drop.
Depends on the cars condition and how you drive.
Lots of short trips you are better off every 5000k.
Hows your fuel economy? Fuel economy is an indication if your dumping fuel in to the oil excessively.
To truley know you need to do a few oil analysis.
You are comparing 2 different oils running in 2 different cars??
Mobil 1 0W40 is probably their best M1 range they offer here in Aust. It meets MB 229.5, where it is used in cars who's OCIs of 30,000ks+ are the norm. For it to go 'off' in under 5000km just by looking at it is just an assumption, especially with no oil analysis results. smile.gif Perhaps the thinness of the 0W40 promoted more oil consumption, same with the Castrol R 5W30.
I suggest you try comparing the OEM certs between Motul 8100 and M1 0W40 and you'll see which is superior.
Sir-D, Helix Ultra will do a 10,000km OCI comfortably on a stock motor, providing its in good condition.
An oil that goes dark is cleaning and suspending crap better than an oil that doesn't. I'd much prefer my oil to go dark than stay light.
Good to know and I agree with you on the first point too.
Just for reference I am using Mobil1 5W50 in my GTR and its not 'using' any at all.
Its also gone quite black since my February oil change.
Have to say that Shell Helix Ultra is performing pretty well in my car. Economy so far seems pretty good. Just got under half a tank of petrol and the car has done around 250 KM... car is auto.
Also the revs are smooth and no harsh noise.
SHU is consider kindda >_< over here due to it's sluggish performance and high cost for a group III oil.
Well busky2k i couldnt get the mobil or the motul as i went to supercrap and they dont stock it, i ended up buying the 0w40 castrol edge and a pure one filter. It should do the job.
Once again thanks for all your advice.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
