Sorry to sound stupid but from the first post should I consider Motul 300v to be the best oil to use? Where can I get some?
I have a R33 RB25DET daily driver so should I be using 10w30?
Thanks in advance!
I dont think 30 is high enough, personally id go for a 10w 40, if the engine is using oil then increase it to 50
300v is a good oil , its a mixed opinion subject, but most high quality synthetic oils are good enough, i prefer to pay more and feel reassured, I found Mobil 1 Gold to be a good one, currently using Royal Purple but might switch back next change..
It's only got 80000kms and doesn't seem to be using much oil at all, also temp needle never over half.
Previous owner said he always ran Motul oil but not sure which one, I'd like to continue using the same one because its a nice drive feel ATM, so 300v is the best choice then?
Also does the oil filter make a huge difference? It's got a light blue one in there now, can't read the brand.
sougi bit hard considering its off the road. i got a btach of mobil1 5w30 for free from work the other day put it in seems to be ok so far but when warm the oil pressure on idle sits at about 20psi on the autometer guage
300V is probably overkill for a daily at stock power, can't get it in 10w30 without mixing anyway. Maybe if it had 300kw+ on the street, or was taken to the track I would spend the premium for 300v.
4100 turbolight (10w40 semi-synth) would be more than suitable if it's a stock rb25det, next step would be 8100 (full-synth) x-max (10w40) or x-cess (5w40), then 300v (full synth double ester)
It honestly is a complete waste of money. Get a nissan oil filter and motul 8100 xcess or the full synth sougi one if anyone still has it (probably not).
300v is over $100, if you change it every 5,000 that is $2000 over that time! you could buy a whole new motor and have change for that haha.
Edited by Rolls
I think mobil Gold is my choice, i never used oil using that one, now i use a little with royal purple.. so who knows lol
Edited by SliverS2
$2000 over 100 000kms
for alot of people who dont daily drive there cars thats like 10yrs +, twice a year change, so $15/month for the best oil, but lets not go into too much detail here ok, lol :whistling:
You are right, but most people will keep their skylines for what ~5 years before upgrading or moving on yeah? It is just putting it in perspective, the better oil really won't make ANY difference, might as well save your cash yeah?
Its not like it is an 8 second drag car where it might means you get 20,000kms out of the motor instead of 10,000.
yeah thats right,
could really just put shell helix in , probably wont notice the difference over a few years, i just dont like to skimp, but probably end up doing the rb30/25 deal eventually cause i dont wanna sell after spending thousands on it now..:unsure:
yeah thats right,
Exactly, something I keep saying, 25w50 $5 oil will almost certainly not kill your motor, probably burn a lot of it and might clog the turbo feeds eventually but it won't be instant death.
Might not sound/feel as nice though whistling.gif
Roberto, the guys above are all dead right. I've never read a bad word about motul 8100 or 300v. But you can experiment with oils, see what you like. Just change every 5000km and you're sweet (some oils may last up to 10000km, your call on that).
On filters, I seem to remember buying k&n filters for $22. k&n are a fairly well known brand, the filter is almost certainly going to be better than ryco or nissan, and for a couple of dollars more I thought it was worth it. Also, and MOST importantly, it has a nut on the end so you can use a spanner to take the filter off when it's time for a change :D
Drift do on their filters too, I once picked up 3 drift filters for $20 each from autobarn on sale, was very happy. It's worth keeping a look out for oil and filter sales and stocking up.
Oil change diy, follow this and you'll be sweet.
http://www.skylinesaustralia.com/forums/topic/10035-my-first-skylines-guide-to-changing-your-oil-and-oil-filter-in-an-r33/
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
