Google "Fumoto" oil drain valve if you haven't heard of it...
Installed one of these on my R33 a while ago and not only does it make oil changes as easy as flicking a switch (no more sump plugs and washers and oil pouring out over your hands/spanner), it looks kind of cool too :)
Very cheap for what it is!
The k&n with the nut, what a brilliant idea! Why don't they all do that...
well considering filter is only meant to be hand tight I would think its pretty pointless just like changing your sump plug washer..dont overtighten things in the first place and you wont have any problems :thumbsup:
Thanks for the advice Rolls, I think I'll go the cheaper option Motul, does seem to make sense when you put it in the new motor perspective.
Now... Where do I get my hands on it? Supercheap doesn't stock Motul right? I'm in Sydney.
Where do I get a Nissan oil filter?
if your after motul 4100 turbolight check out just jap in the traders section... bought 5L for 80 odd bucks including postage which only took a day
I use one of these,just like you said makes oil changes a breeze. :yes:
It definitely looks good. How secure is it though birds, I'm guessing you've never had any trouble? Does it feel like the safety latch will protect against a wayward stone flying up under the car?
I've only ever done filters up hand tight and only ever managed to undo one or two by hand (of a couple of dozen changes at least). Having that leverage/grip makes it so much easier. Though you can always just stick a screw driver through it (never done it myself but have been tempted).
Isn't 4100 turbolight usually a fair bit cheaper than that? Seeing as 8100 is usually $75-80?
yeah it was like 60 bucks for 5L postage was $20 ish.... lol the screwdriver trick... i thoroughly dont recommend it - some say its ok - for me an oil change usually takes an hour.. it took days to finally wrench my old filter off after breaking just about every tool i had
Doesn't sound right, 8100 xcess is only $60 when you shop around, 4100 is cheaper again. Worst case 8100 is $80, 4100 should never be that price.
well I would think that means your doing them up to tight wouldnt u?
Also are you putting them on dry or wet, smear a little oil around the seal and half fill it with oil before you put it on..
Anyway, I guess some people just dont get it, which is why they make filters with little nuts..
i dont see why anyone would use a semi synth 4100 when you can get a full synth 8100 for about the same price .. is it because its called turbolight people think its better for turbos :unsure:
