Once my engine Is running at normal operating temperature, the 40 grade feels great...I wouldn't want to or need to go any thicker unless I was tracking the car. Engine temps are very consistent even after a thrashing. Again, it won't kill your engine to run a 10w60, but the 40 does feel smoother IMO.
Yes I would recommend Syn X 6000 for an RB26. I have been using this oil in my RB25 the last 5000-6000km and it's been good. Much the same feeling as Sougi 6000 had. About due for an OCD change, though there would be plenty of mileage left in it if someone wanted to stretch for the 10,000km.
Had some experience with Royal Purple API 10w40 oil, ran it for 11000km in my rb26 on a single shiite fram filter (noob mistake) and the oil was still light to mid brown, admittedly the motor was fresh but the oil was still relatively clean and the pressure was still 3.2 bar at warm idle, 4 bar cold. No oil analysis just my personal observation for what its worth. Currently running RP HPS 10w40 with a K&N gold HP2008 oil filter, car seems very happy.
I'm using Gulf Western Syn-X 6000 in my NM35 Stagea; I reckon is very similar to the Sougi S6000 that I was using previously.
$150 for a 20lt drum; what more can you ask for? Basically getting the 4th change for nothing.
before my local Autobarn stopped selling it, 8100 was around $80 / 5l.
I did a LOT of reading on oil before I did my first oil change in my new car - the Royal Purple seems to be good due to high levels of ZDDP in the HPS at least, however their marketing claims have been called out as BS numerous times on the BITOG forums. Also hard to find and pricey unless buying from a workshop.
Spotted RP on the shelves at Supercheap the other day
Must be everywhere now because this was in Launceston lol
Remember at the end of the day it is just oil, at $80 a change you could afford to replace your stock r32 motor every 37500kms instead.
Gotta weight up how much it is actually worth spending on oil.
Where the hell do you guys get the Syn-X 6000 from? Supershit/Autoshit/Repco doesn't stock it...
Prob a GW distributor?
http://www.gulfwestern.com.au/GW_nearest_stockist.html
not 100% accurate as i can get it in Tas but they don't list the people i use (Independent oils in Ulverstone)
I live not too far from GW head office in the 'Riff.
You pay for it, & they make you go and get it of the racking in their warehouse...
Worth it.
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
