Hey guys,
I'm not too knowledgeable on oils but i have been using penrite 10-70 in my 98 R34 GT-T, its been good but the oil temps get a bit higher than I'd like with little effort (just normal driving sees temps around 100-105°c quite regularly). I just switched to Nulon 10-40 thinking that the penrite wasn't draining to the sump easily enough but it doesn't seem to have brought the oil temp down.
My water temp is aways good as i upgraded the radiator and added a twin fan set up.
Im just wondering if anyone has any advise the can give me, or if both my choices for oil are wrong.
Maybe its the symptom of another issue?
Any help would be appreciated.
Thanks guys
-Jimmy
Something is causing the heat, maybe timing is off (retarded) causing engine temps to skyrocket passing through the engine or turbo. You might want to confirm what your coolant temp actually is, as it could be heating up the oil via the oil/water exchanger.
The new penrite marketing is alittle wierd, the 10w70 is actually 10w60, admitted for a street driven car the hot rating is completely wrong, you should be using one with a hot rating of 40, 50 max. I highly doubt it's the oil choice that is responsible for the heat problems.
thought to post this as i inquired with Gulf Western regarding their Syn-X range as to what base stocks they use, this was the response i got;
Daniel,
We use Group III in Syn X 3000 and Group III / Group IV in Syn X 6000.
If manufacturing licensed blends in modern API grades, the engine tests are only performed in these base stocks.
Regards
Ben Vicary
Gulf Western Oil
to be claiming Syn-X 3000 is a Motul 8100 equivalent without any justification other than that it feels the same doesn't really tell the whole story about the performance differences of these 2 oils
I've also read reports the the Mobil 1 range is made from a different formulation from a 100% Group IV PAO base, to a Group III / IV blend - which is same as the Syn-X 6000 variant of Gulf Western
although in this day and age, oil's additive packs are just as important as the base-stocks, at the end of the day group IV PAO base stocks are smoother and more expensive to make, Group V being even more so - an oils manufacturer's certifications should also be taken into account
so most things you can grab from a brick-and-mortar shop are made from either straight Group III or blends of Group III / Group IV base stocks (Nulon, Castrol, Mobil, Penrite etc)
the only real Group IV formulated oils i can think of are Motul's 8100 range, Royal Purple and Redline
and Motul 300V and Amsoil being the only real Group V oils
hope this clears up any confusion, not trying to start any wars, just thought to share some info i've come across in my reading
Edited by squareznboxez
I've actually been wondering if Syn-X 6000 was a true synthetic (100% PAO Group IV stock) myself, for the price I've been having doubt about it, as it would seem too good to be true. But what really matters to me personally is that people have success, at least GW isn't charging us for it, as if it were a true Group IV oil like Nulon tries with their Group III/IV blend "full synthetic"
group III's are allowed to be marketed as '100% synthetic' in Aus which is why everything you see in stores is labeled as synthetic
obviously if your car is not giving you grief with Gulf Western (normally doesn't until its too late), but to say its comparable to other established group IV oils or even group III/IV blends is a bit silly without any proof of a UOA as different countries invest heavily in formulating additive packs for their oils
Tried searching within the forums (and some on the internets) without much luck. Has anyone used any of the Liqui Moly products?
Also a question for the guys running 300V - are these being run in street cars? I'm curious on the level of detergents as internet "research" indicates it's more a race oil relying on regular oil changes to prevent build ups and coatings.
Liqui Moly - they make good products - made in Germany IIRC, more popular with the euro crowd and are thus carry all the euro certifications (VW, BMW, Merc etc) which are among the highest in the world - would place them amongst the likes of Mobil 1, Penrite SIN series, Castrol Edge etc
Motul 300V - has been confirmed by Motul reps as totally suitable for street/road use and change intervals - i've seen UOA reports of it being used for 12,000kms / 12mths including track time without any issues - has been recommended that u stick to under 10,000kms and 9 mths of use to get the most out of it - the short life of this oil is made up with its ability to lubricate very well under extreme temperatures/wear
Been using nulon 1040 for years,great stuff,no lifter noise on cold start.
Change oil an filter every 5000 or less,do a lot of ks,330000 plus now.
My ol 33 really is a daily,mainly long distance on highway. :yes:
Was looking through Motuls engine oil range and came across Nismo Competition Oil 2212E 15W50.
This is the product description below -
100% synthetic racing engine lubricant developed for supercharged-equipped, high output, high torque engines such as RB26DETT, RB25DET, RB20DET ans SR20DET. With its outstanding ability to avoid oil film damage caused by rapid torque increases, high oil temperature and fuel dilution, NISMO COMPETITION OIL by MOTUL is the best protection you can get for your engine.
http://www.motul.com...f%5Brange%5D=25
Has anyone used this oil ? Would love to hear some feedback.
meant to note it a while back that iv been using the Castrol Edge Titanium fully synthetic for a bit in my HKS turboed 320rwhp 1993 R33 GTST with 155k km on the clock.
used the 5w-30 over winter (tho perhaps a bit thin for a car of this age?- seems fine tho and its what iv always run) and now the 5w-40 coming into summer (WA).
Seems very good, no oil being used but my car never has anyway.
Got it when it went on special at REPCO so is a decent price for what seems to be a good oil.
Edited by jjman
Daniel,
Regards
Ben Vicary
Gulf Western Oil
Great post mate, very informative. Cheers !
Lots of people seem to be using 10w-40w oils, the manual for the RB26 calls for a 7.5w.
Isn't it better to go the slightly thinner oil at 5w instead of going to 10w?
Is it really much of a difference?
I am thinking really, as long as you change the oil frequently and its of a reputable brand/quality it shouldn't matter too much?
That said, completley different question.
Had coolant contaminating the oil in my RB26 (head gasket).
Head gasket done, but worried their might be a little bit of coolant in my oil, Whats the best way to flush it?
Edited by Booki
Supercharger equipped engines such as *insert Nissan TURBO Charged engine range here* LOL
High Torque engines such as RB20DET?
lol
Edited by TTT
500ml Auto trans Fluid in to engine oil, bring it up to operating temps, dump oil when hot, replace oil filter and put in new oil.
wear gloves or have towel ready to reduce burning your hand on the oil.
Edited by TTT
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
