I was desperate to get a change done today so I just got the HPR 10. My oil reeked of fuel :(
niZmO_Man my (local) Autobarn had 10 Tenths Premium but unfortunately not the Premium 0W-50 which is what Penrite was recommending for me.
I’ll be getting some Racing 10 (10W-40) from Repco as per the suggestions above.
Thanks guys!
i use 10/40 tens racing with no oil control mods, car is regular daily and gets limiter bashing on the track days
picked up 4 bottles at repco for 55
try 10/40, then try 0-5w-50 on your next oil changed after that and note how much oil has been consumed
went from castrol to everyday penrite with the same grade on sisters daily and has fixed the power band issues it had
Edited by Dan_J
I use pretty much same have 250rwkw on my 34GTT and use 5w-40 even when taking out to track for drifting. I am going to put the 10w-50 when I head out to matsuri as it will be hotter then and a lot more track time seen than usual
Engine : Nulon hi tech fast flowing 10W40 synthetic + one bottle of Nulon E20. - Very smooth.
Gearbox : Nulon Semi-Synthetic 75W-90 Smooth Shift. - Tightened the box + easier cold shift / less crunch.
Diff : Nulon SAE 90. - Tightened up and stopped a reversing clunk.
Probably posted this before but all of these have improved my car. (Daily Driven)
Very Happy. :yes:
i cant say i know much but as far as going thicker grade with no oil control mods it might leave you with more oil in the head not draining back to bottom end due to thickness
others may have actual answers to this.
Can anyone tell me what is a safe oil temp for my r32 gtst? its a drift car with basic mods like a r34 neo turbo, hks intercooler, turbo back exhaust and a good cold air intake... also has some cooling mods such as a triple core alloy radiator, r34 viscous fan with shroud and large trust oil cooler with earls braided lines etc.
The oil is getting to 100 degrees very quickly, I always stop around then and let the car cool down but would be nice if I stay on the track for longer :) I was using penrite hpr 10 (synthetic 10w50) but have tried hpr 15 (15w60) and that made no difference.
Is there oils that are safe to use at say 120 degrees? Or could I possibly have an oil pump thats getting tired or some other issue?
any help would be appreciated :)
THanks
THanks
Oil temp of around 100 is pretty safe/normal I would have thought? My car sits on 80* day to day, and gets up to 90-95 quite quickly if I take if for a bit of a blast, and also comes down quite quickly once its been driven normally. I have a oil cooler in the front right guard that gets decent airflow
Im looking at using Penrite for my next oil change, seems to be quite popular
I haven't tried the 10 tenths range yet, would a different oil actually lower the temps? or just safe to use at higher temps? will a thinner oil cause less friction thus lowering the temp? I also change the oil about every 4 drift events...
I would be happy if it stayed at 100 degrees but it will keep climbing unless I go into the pits :( hottest I've let it get was 120
That's actually a pretty good point didn't even think of that. I may be better keeping my thinner oil since I don't have issues with burning of the oil or blow by
Yeah give Racing 10 (10W-40) a go. I think they have a thicker oil in that product line. These are $75/bottle, but they should be more stable when running at 100deg.
My car is street driven, but switching from HPR to SIN I found the temps stayed a little bit lower (barely detectable).
Still using nulon 10 40,near enough to 430000 ks now,fantastick stuff.
:thumbsup:
Genelle, try the Nulon Semi-Synthetic 75W-90 Smooth Shift (Gearbox) and Nulon SAE 90 (Diff).
Fantastick Stuff Indeeds. :wave:
  • Like 1
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
