hey guys just wondering what oil weight you would recommend for a fully built rb25 its oil change time and i was gonna go with redline 15-40w i have been using castrol edge titanium 15w60 but someone suggested this isnt a good weight for goldcoast during summer? i know this has probably been covered in the previous 152 pages but i dont have time to trawl and ive done a few searches but not really answered my question. so i thought i would get some opinions
anyways cheers for any replies
Ask the engine builder.
They put it together and know the tolerances.
iv always used the Castrol edge titanium 10w40 in W.A. summers and seemed to do the trick just fine.
Not sure about your built engine tolerances tho so the recommendation to check with the builder is a good one.
Nonetheless, as the motor was recommended stock to run 7.5W30, I think 10w40 is a good number for these older motors and warmer conditions. Also a fully syn is far beyond the requirements the guidelines note.
I've always used Castrol Edge Titanium 10w60 and it's on special now at Repco for $59 for who ever else uses it.
I snapped up a box while I had the chance.
Do you track with that oil too? What sort of temps are you getting at track if you do?
I hate this process haha lol, so boring waiting for all the oil to drain out lol, would it hurt to put some compressed air through the oil cap to push the oil down a little.
Edited by MrRx7s3
Well I've put the Penrite Racing 10 10w-40, I'm impressed, engine is as smooth if not smoother than the Royal Purple, oil pressure is better than with the Royal Purple, overall so far with a short drive I'm happy :-D.
It wouldn't hurt, it would just go out your intake....
Drink beer while it drains. Perfect excuse.
  • 3 weeks later...
Just put in Shell Helix Ultra 5w-40. Best oil I've used for the RB25DET.
Smoother quieter idle, very smooth running and revving.
Had Penrite HPR5 5w-40 in there and that was not bad but it seems better with the Shell.
Before that had Valvoline Synpower 5w-40 which made the engine run very smoothly but the Shell seems slightly better.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
