Ryco is a good brand
I use the drift filter, because they have a magnet built into them which I cut open and check every service even though I know the bearing are not metal lol
Diesel oil can be used in petrol motors but not a good idea for petrol oil in diesel motors and not a bad idea for performance motors, I used Castrol magnetic diesel oil for the run in on my RB2630 then switched to Brad Penn 10w40
  • 3 weeks later...
From what i recall from ppl who have cut them open Ryco are just ordinary budget filters. From what's available in Australia, K&N are supposed to be good. Generally OEM filters are good, so i'd imagine Nissan filters would be a good option too.
I done a search and couldn't find a post about this - https://www.ozbargain.com.au/node/163258
Can anyone comment whether Castrol Edge 5w40 would be good for a Nissan Skyline V36 350gt?
Edited by Leon.T
Should be ok, but it looks like its a dino so dont push the OCI. DI motors (is yours VQ35HR?) often contaminate the oil with fuel more than non-DI so shorter OCI on a dino is not a bad idea anyway. What does the owners manual specify? Make sure it meets all those requirements.
so is nulon's touted 'fully synthetic' range actually hitting that mark?
it's so hard to work out what is and isn't actually fully synthetic because the line seems to blurred
You will have to send them an email and ask. This is one of the reasons why I use Penrite, all info is available on their website, they even tell you about the additives used :thumbsup:
Edited by Missileman
If it says fully synthetic on the label, it must be fully synthetic or they're in breach of the consumer/fair trading legislation.
Fully synthetic can mean either;
Group III - hydrocracked mineral oil (there was some argument about whether this should be considered synthetic when it came out). All the cheap synthetics will be mostly Grp III.
Group IV - POA (or the new Gas to Liquid oils) eg Mobil 1
Group V - Esters eg Motul 300V or Redline.
running a lucas race 20w50 where can i get this type of oil from brisabne area or something the same of another brand
Unless you have a problem with oil pressure, i'd think about Penrite 10-Tenths Racing 10W-40.
That should be "Unless you have a problem with oil pressure or temperature" and temp should be <120 degrees.
  • 1 month later...
What oil would be best for a gtr32 with a built motor? Previous owner was running Shell 10w40 semi synth with changes every ~8000KMs. Car is mostly street driven with the occasional midnight run (only driven couple times a wek). Is a semi synth and 10w40 ok? Recommended mobil is 5w30 thoig for a standard motor
anyone use moly-chrome 10w-40, i just put some in the Ls1, its very clear and clean looking compared to the penrite oils that have a darkish look straight out the bottle, autobarn guy said its german and good stuff.
Do you mean Liqui-Moly 10W-40? Its German and well respected. Don't judge an oil by its colour. You can't draw any conclusions from colour. For example. oil that looks black after use may just be doing a good job of cleaning the motor's insides.
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
