yeah that's it, Liqui-Moly, looks like a good product, its nice and light, the engine feels more responsive so will see how it goes.
Did you have a 10W-40 in there before or something heavier? Generally lighter oils should make a tiny bit more power and be a tiny bit more fuel efficient.
yeah I had some Castrol edge 10-60w, it has a bad lifter problem so I tried many flushes and oil changes and still there so ill have to replace them,
Also I might add, if anyones using flushes just be careful, cause after using 2 engine flushes, it seems the engine has picked up some noises, more noticeable is piston slap, probably cleaned carbon from the top of the pistons :(
Don't judge an oil by its colour. You can't draw any conclusions from colour. For example. oil that looks black after use may just be doing a good job of cleaning the motor's insides.
Agree with caveats. New oil colour doesn't mean anything you're just looking at the colouring they added in the factory in many cases (additive mix and stuff).
Old oil colour is an indicator of how many particulates the oil has managed to trap. In this situation dark brown oil is a good thing, because the oil has taken the contaminants and trapped them in suspension. If an oil is really black then your change interval is too long or you have switched to an oil with more detergents in it and it has dissolved deposits that your last oil was inadequate in clearing away. Honey coloured oil means it is not doing its job well, assuming you are burning petrol. LPG/E85 doesn't produce any soot so oil will still look honey coloured even when it has reached the end of its service life. This is bad because the oil is not lubricating properly even though it looks new.
You can draw conclusions from colour of used oil but only if you know what colour it started out, how long it's been in the engine and what fuel the engine has been burning. Without that information it's useless.
that's blows my thinking away, I used to use Mobil 1 0-40w, $100/bottle, that was clear going in and only went to a honey colour after 5000k's on 98,
It did change colour after one dyno session, must of been a long session cause it was very dark colour that time, maybe the car just doesn't get flogged enough for it to change colour
  • 1 month later...
Hi guys. I've been using HPR 10 in my daily RB25DET and would like to replace it this time around with probably a Mobile 1 5-50, keen to see how a slightly more premium oil goes. My engine's just about to tick over 200,000km, would it be wise to stick to 10w or can I go for a 5w or even 0w without sacrificing protection? I've been trying to learn from people's experiences on different oil weights in higher k's engines, but info is really mixed overall. I've seen comments saying don't touch lower viscosities if your engine has high k's, and other people saying it's fine. So, what's the go?
That M1 is 17.5 at 100DegC and the Penrite is 19.6 at 100DegC, so yeah the Mobil is a bit thinner. Pretty unlikely you'll feel it with the butt dyno, but if the oils are around the same price, sure, give it a go.
If the engine still runs well, has good oil pressure and doesn't consume oil i'd try a 40 and see how it goes. Keep an eye on the dipstick to see if it starts using. Often the first fill after you change oils is not a good indicator and you should try at least two fills to see how it settles down.
FWIW I run Mobil 1 0W-40 in my cars, but might switch to Nulon to support the local product. Nulon 10W-40 is one of the thicker 40s, so you could try that.
  • 3 weeks later...
  • 1 month later...
="booba32" post="7519451" timestamp="1429511959"]
Just after some advice, i have a 94 r32 gtr as my daily atm, with roughly 100,000kms
What oil do you recommend and what grade should i be leaning towards? cheers.
This whole thread and you still have no idea?
After 158 pages of discussion the jury is out. The best course of action is to just not drive your skyline until further discussion can figure out what oil is best to use!
  • Like 1
I made the switch to liquimoly 10w40 super about 1500kms ago and the oil is already BLACK as. Anyone using the liquimoly stuff and does this mean I should flush it out (prev oil was just a shell semi synth, so thinking the liquimoly is cleaning much better).
    • Nah, apparently the way to do it is just mess with how much timing the engine uses to try to correct idle. So it massively undershoots, then overshoots, then undershoots, then overshoots. So timing is going from 5deg to 45deg to 5 deg to 45deg. But I kinda prefer the car to not lurch around and have a dependable idle. Given it didn't idle for shit and stalled about 7 times on the way home, still yet to drive it for the 2nd time to see if it's fixed.
    • Best chop idle FTW, just add an idle timing hole lol
    • Alright. Many little things have been sorted and the car successfully drove home with an incredibly huge exhaust leak. Unsure if it's simply been awhile, but new heads and cam and intake sound f**kin awesome. It might only be me that notices it though, and it's hard to tell from a 15 minute gauntlet run home and attempting to bleed the radiator. Undertrays on, tools out, road brake pads in, idle un-f***ed, time to do some road tuning. From my commute around town it sounds and drives *really* nice (with a max of like 35% throttle). It'll go to a dyno for a proper before and after once the tune is more roughly dialled in. And @Dose Pipe Sutututu I did learn how to do a proper chop tune at idle. I did indeed even do it, but the car shaking around at idle from the driverr seat made me make it smooth again.. I feared for my engine mounts and clerances to engine bay jank. . After the exhaust is fixed I may mess around with it more. I'm just happy to have it drive around without bucking or stalling which is a WIP.
    • Oh and my rear arms may need some attention too.
    • Bushings are almost done. Check the date stamp 😂 these are likely the original bushings with 27 years and 243ks on them.     Was too dark to get a pic of the worst one.
