That 10-40 everyday Shiite has been out for a while. Used it a couple of times in an sr20, seemed OK. I ended up changing to castrol edge 10-60 to try and stop my flogged sr from making its ugly sr noises. I don't have an sr anymore. I'm now an rb fan. I've got about 15 litres of 10-60 stockpiled in my shed. I'm wondering if it will be OK to run in the rb25?
that penrite extra10 shite confuses the crap outta me. is it a 10w30 or a 10w40?? package says may be used where 10w-30 is recommended.
everyday 10w-40 made the v35 sump seal weep oil, was all wet. switched to nulon 10w40, dry as... so does that mean penrite everyday is really a 10w30 with some extra "protection'?
Yep diesel engine oils usually contain higher levels of dispersants to prevent the soot particles from agglomerating.
Historically they have always contained higher zinc which has significant anti-wear properties. They got rid of zinc in the 80s because of catalytic converter contamination fears but recently started to reintroduce it into petrol engine oils.
I have used it since 2007 in my LS2 and for 5 years in my RB.
When I blew my turbo couple of years ago I pulled the sump off and it was amazing. No deposits at all.
This is a link to the post with picture of my bottom end after 30000 km of abuse.
http://www.sau.com.au/forums/index.php?/topic/22458-The-Goods-On-Oils#entry7381708
Edited by XGTRX
Technically, yes. It acts like a 30 weight oil.
If you put R32 GTR into Penrites recommendation guide, is says that HPR 5 SAE 5W-40 is the preferred one. The new, cheaper one may be a lesser oil.
It's just for my daily and the mrs car so all good. I use Castrol 10-60 in the GTR.
10w40 and 20w50 full syn oils should have everyone's bases covered,
I have no idea why anyone would want to use heavier oils in a high revving motor like an RB?
unless I had no oil cooler and I was bashing through a Dakar rally then maybe I would use a 60 weight
I use the the Penrite Racing 5 (5W-30) when I can find it on special, but most of the time I'll use the HPR Diesel 5 (5W-40) I have the Racing 5 in there now and it seems spin up a little quicker than the Diesel 5 that it replaced.
Will be interesting to see how the thinner stuff hold up during this summer.
  • 4 weeks later...
Repco has nulon 1040 in 6ltrs for 50 bucks absolute bargain,been using this for hundreds of thousand ks fantastic stuff,no lifter noise on start up and lasts for 10000 ks my ol 33 loves it.:-) :-)
  • Like 2
  • 3 weeks later...
Great sticky, did a bit of research and just bought royal purple 10w40 high performance Street for 92 bucks for 5 litres and nissan oem filter for 20. Will hit 5k service on the weekend. Car currently runs smoothly but would like to see the difference at the high end of things after the change.
I'm Betting none.
  • 3 weeks later...
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
