True but it soooo cheap compared to others and I thought how bad can it be! Oh well back to the mobil 1 - might drop the old owner a message and see what grade he was using as it was working really well !
Ok guys... this morning i put some Royal Purple 10W40 with a new cooper oil filter and this is what i have noticed after 100km/s of driving:
- Car idles MUCH smoother and quieter than when using Castrol R and Nuon (comparing to when oil was first changed with both brands)
- Car warms up much quicker on cold starts than before
- Car starts quicker and easier
- Exhaust note on idle is more deep and is not lumpy/poppy anymore
- Acceleration feels 100 times smoother and responsive than Casrtol R and Nulon
In conclusion, I recommend RP for any RB motor.. over any other oil i have ever used!
ROYAL PURPLE
A+++
Regards,
Sarkis
ROYAL PURPLE
A+++
Regards,
Sarkis
Sounds like a good choice you made in the end Sarkis, wat mods you running on your 33 and how many kms? The RP is sounding good, now to check on prices of this in Vic.. only one place that is remotely close.
Hey Mark, i just hit 70k and my mods are:
- 3" Split dump ---> Hiflow 4" Steel CAT ----> 3" CAT back with resonator ----> 4" cannon
Dyno'ed 165rw/kw with every thing else STOCK! (7psi) and misfiring coils...
since my dyno i have:
- Replaced coil packs
- Turbotech set to 9psi
it feels that i have gained easily another 10 - 20 rw/kw with the extra boost and fresh coil packs...
Next step:
- FMIC
- APEXi PFC + tune
- Pod with CAI
I will always use RP for every service... highly recommended! Car feels brand new! Its unbelievable the difference it made...
Regards,
Sarkis
Yep use a mineral oil for run-in, definitely. During run-in you actually WANT the engine to wear, and grind off all the high points so it turns smoothly. After a while switch to synth so it doesn't wear out :nuke:
Yea the Castrol 5W30 will be fine, another decent mid level oil is Valvoline SynPower... just make sure you do regular changes every 5000kms or 3 months which ever comes first... personally i would be using a higher quality full synthetic in any turbo motor such as Royal Purple, Mobil 1, Redline and Motul...
Cheers
hey guyss
i got a R32 GTS-T
mild mods, not much
will see how it performs on dyno in 2 weeeks :laugh:>_<:laugh:
not sure wat oil previous owner had as im first owner since japan arrival.
but i get my car tuned by bel garage in syd and they advise elf 10w50
so ive been using this since
its pretty damnn good, havnt had any troubles with it at all.
tell me wat u guys think bout it
Hey Guys,
Just wondering what oil i should be running now that its warming up :)
I think i used to use Castrol Type R synth around this time last year, from memory... does anyone know the weight and viscosity of the Castrol Type R?
I think the mechanic used Penrite 10w60 or 10w70 when he did the timing belt change 5,000km's ago...
10w60 - does that sound ok for summer in a 140,000km+ engine?
Edited by Mr Italy!
Eagle Auto Spares
92 South Gippsland Hwy
DANDENONG
03 9793 5544
Just rang them and they are charging $90 for Royal Purple 10w40. Almost cheaper to buy in Sydney and freight it down haha.
does anyone know the deal with frieghting oil? can u do it through normal post?
