Just stick with the 5W30 in summer. There's no real need to go thicker as the oil temps will still roughly be the same when its the motor is hot anyway (as the coolant indirectly will remove the heat).
and ur cold start cSt rating will be like much less thanthat of the 10W40....
one question for Busky and trex...I use a 10W30 in my fto and is the goods....I had been using a 10W40 Redline in my Rb25...what u think about lowring it to 10/5W30 as we move into summer...prop. the same as post above.
its a rb25 worked to 300rwkw...I went the 10W40 redline as I thought it to be a good general thickness...yeah might gove the 30 a go...
what weight and brand do u use??
What's your avg oil temp?
A general rule of thumb is to increase oil viscosity by a grade if oil temp increase by 10'c.
hi, im the guy who used to put repco semi synthetic in his r33.
I did my oil change last weekend using mobil1 0w40 and omg can't believe how much smoother it is now. (either mobil1 really good or repco oil just pure cr*p) for some reason i have a feeling its the second one
khunjeng, stay with Redline, its a good oil. Or Motul's 300V "Double Ester" formulation looks great too (mega dose of Moly!).
I'm going to stick with the redline for sure...I havn't got a oil temp guage - i was going to install one but then didn't. Maybe its a must - I assume its hotter but then again I only take it to the max on the odd occassion and its driven on the street.
btw Trex..finally got into the BITOG..saw a few of ur posts...just sussing out UOA now and will post some results using the 10W30 redline.
Have you found a UOA kit yet? Which company are you senting for analysis? I'm now using Wearcheck usa
yeah I have and got the sample sent to me already. I used a company that Busky2k gave me...I will chnage the oil and take the sample and send it off..I'm excited :laugh:
Been busy changing ATF and GB and DIFF oils in other cars...omfg ATF changes suck arse.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
