The Goods On Oils
PHaT MR30
Pressure is directly proportion to viscosity, the thicker it is the higher is the pressure. This also mean higher pressure will have lower flow rate. You need both flow rate and pressure to fully optimize the operation of the oil system. IMO 50wt oil is just too thick for most application except racing or autocross....
Rather than start an argument I would rather pose a question.
First things first what you have said is partly correct. A higher viscosity fluid will create a larger pressure difference when measured from one end of the pipe it is being pumped in to the other. This means a higher output pressure at the pump is required to achieve the same flow rate.
BUT
There is more than one type of pump. For a centrifugal pump (like your water pump) the output pressure has a huge effect on the flow rate of the pump. For a positive displacement pump it has ABSOLUTELY no effect.
So what type of pump is your oil pump?
BUT
It does when the bypass is wide open; in essence the thicker oil creating high pressure also causes a huge effect on the flow rate of the pump as it has to dump a lot more oil to hold its specified oil pressure.
With a 5w40 I see ~90-95psi of oil pressure over 3500rpm.
Nah i'll never take the odometer reading as gospel hehe. I just want to know if its a safe things to use. Ive been going through this thread and man ive got a headache and I just want to know what oil to buy tonight when i go down to supercheap. I just want something good quality and something quietens down my lifters abit during start up thats it. any suggestions for my 1996 R33?? Im sure its not rocket science but after reading a few pages im like damnnn oil choice is a massive decision.
yeah, you've asked quite a few times :(
I've answered with Mobil 1 a few times as well :P
0w40 in my car, took a little less than 5 litres i think. As i've said before, RB lifters are fairly noisy anyway, but the Mobil 1 did quiet them down a little, for me. NEO R34, don't know if that makes a difference.
i can't say anymore than what i've already said. I've got 0w40 in my car, and yes it made the lifter less noisy.
can't answer your question any more straight forward than that. And if people like Trex101 are telling you it's fine, that it's 100% cool. They're the sorts of people in this thread that i made my oil choices from. Trex101 and khunjeng, etc...
that's cool :(
mate, i was exactly the same, worrying about which oil to put, concerned about this and that. But some of guys in this thread REALLY know their oils. Mobil 1 is a good starting point, at a reasonable price and having 0w40 is fine. Then you can go German Castrol, Redline, Motul after that if you're keen.
i know exactly what it's like to be paranoid bout the car, especially with the oils. I also did my gearbox and diff at the same time, so i was 3 times as paranoid! haha
Maybe just PM Trex101 or khunjeng with your EXACT concerns and worries, and grab their opinion :P
nope, will still be cheaper i'm pretty sure :rofl: Even melb people have to pay for postage. The difference isn't that great between posting here or interstate.
ah okay yeh ive found those rates they aint that bad...
Pretty keen on the royal purple stuff for that price, anyone using this in theyre cars?
Guys,
Was just enquiring about gearbox oils at the Outlaw Speed Shop here in Adelaide, and got to talking about engine oils too. I was passed on this article to read/keep and had to share with everyone as it has some REAL eye openers.
I will more than likely be using the Royal Purple next, far and above the others for value for money I reckon. Almost makes me want to dump the Motul 8100 excess in there now!. However got to say that the Valvoline shocked me!
Cheers
Lee
Oil_Compar.pdf
Well I didnt get a price from Outlaw, but the listed price in the comparo is $79.99 compared to $92.99 for the Motul 8100 Excess, which you can get for cheaper than that.
By value for money, i meant for similar dollars to Motul, get far better protection for a full synthetic.
For a Semi synthetic, seems the Valvoline durablend is the go.
Its all in the PDF I attached to my post ;)
Edited by Hotwire
Guys,
Cheers
Lee
This article from StreetCommodore is very misleading, this Timken test are only good for grease, not oil. The editor has admitted the test is flawed and not representatives of actual engine condition.
StreetCommodore reply:
http://www.streetforce.com.au/news/01_oils_aint_oils.php
Wow,
Thanks for pointing that out. So the verdict is still out then LOL
You know, i can get better wear reading with head and shoulder shampoo then all these oil tested. The chorine in there are a very good extreme pressure additives, it just that when you include it in your engine oil combine with moisture, you will form hydrochloride acid.
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
