The Goods On Oils
PHaT MR30
LOL so hey can anyone provide sum info on royal purple for skylines??.. or is it like a super hard thing to get outa people :P
You know, i can get better wear reading with head and shoulder shampoo then all these oil tested. The chorine in there are a very good extreme pressure additives, it just that when you include it in your engine oil combine with moisture, you will form hydrochloride acid.
This article from StreetCommodore is very misleading, this Timken test are only good for grease, not oil. The editor has admitted the test is flawed and not representatives of actual engine condition.
StreetCommodore reply:
http://www.streetforce.com.au/news/01_oils_aint_oils.php
I concur. THis has been covered many times. I dont put faith in what someone said when they have no credability.
Hey guys,
been reading the first & last few pages...
I've come to the conclusion that I should go for the mobil 1 0w40 & buy about 5 litres for my car
I have an R34 GT-T with a turbo back exhaust, pod and 60,000K's
Is this a good choice? Still new to the whole D.I.Y service thing
Any info is greatly appreciated guys :rolleyes:
Hey guys,
personally i 'think' the zero wt oils are too light, they recomend from factory 7.5wt... keep in mind our cars are round the 10yr mark so seals do tend to give a little, i would think the 10-30 mobil one would be overall safer.. it might take a little longer to warmup than the zero but... meh
Some castrol and Penrite facts;
The name comes from Castor oil which is ok, they then turned their hand to esters.... and failed giving synthetics thier bad reputation early on in the piece.. they no longer use ester... it is left to oil professionals.
did you know that castrol/Penrite Sin fully synthetics are actually only partial synthetics? the only full synthetics in australia have to say 100% synthetic on the bottle.... stoopid loop hole in consumer law.
Also to achieve a wide spread of 10-60 (penrite too) you need to add alot of additives these additives are not lubricous therefore actually reduce and dilute the amount of lubricant in the oil....
Where do u get that info from?
hehe dont believe me? walk into repco autobarn or supercheap and make a list of all the oils which say 100% synthetic.... you will be suprised you will find 3 or 4 the rest are marketing hype.... you are buying the name or slogan not the oil.
MOBIL 1
MOTUL
NULON (crap though)
REDLINE
Of course there are other boutique brands like AMSOIL etc but they are not available at most outlets.
(URAS @ 13 Jun 2007, 02:04 PM) *
You got to be joking.
Edited by Trex101
Trex you seem to know your stuff about oils, is this true?
The other thing, even if Castrol is not 100% synth, I doubt it matters much since most people change their oils 5000-7000 KMs.
MOBIL 1
MOTUL
NULON (crap though)
REDLINE
How do you define 100% Synthetic? Technically, engine oil consist of 70-80% base oil + 20-30% additives carrier fluid. The oil can be call a Fully Synthetic once the base fluid are 100% group III grade & above. The formulation of modern oil is very complex and can't be judge base purely on base fluid (but of course a group IV or V fluid will be more value than group III). A well formulated oil got to have good base fluid couple with strong anti-wear additives package, one can't just work without the other.
Group I - mineral
Group II/II+ - hydrocrak (VI below 120)
Group III - hydrocrack (VI above 120, mineral derive "Fake Synthetic")
Group IV - polyalphaolefin (man made Synthetic)
Group V - Ester & other un-group fluid (Ester or Polyolester, super high grade Synthetic, good for aircraft jet engine).
Well, to answer your question. In my opinion
MOBIL 1 --- are using group IV base fluid aka Fully Synthetic
MOTUL --- depends on type, the 300V are using group V ester base, race spec fully synthetic.
NULON (crap though) --- don't know about this brand but i doubt it good stuffs since they promote PTFE in their oil additives.
REDLINE - group V Polyolester + very overdose of anti-wear additives, race spec fully synthetic.
Edited by Trex101
Which makes the 8100 X-CESS well priced being a grp IV when it goes for $59. Autobarn have jacked their price lately but there's plenty of other places where its available at the usual $59.
Where abouts?
Group I - mineral
So what group does my current oil Castrol Edge Sport 5w-30 belong to?
Not familar with Castrol Edge but the 5w30 could possibly be group III. Only a few Castrol oil type are PAO. The 0wXX type are probably PAO as they need the PAO for such low cranking point.
I'm sure its better then any oil that was around when your car was made.
Good point.
I guess Im just being cynical.
I first was using Shell Helix Ultra, got told its not that good. Also Ferrari endorses it quiet a bit and their engines are prone to rebuilding often... might have more to do that they dont get driven that much but still.
Then I moved onto Castrol Edge Sport (improved R formula)... I want to stick with it as its rather good value and prior Ive only read good things about Castrol.
I dont want to really pay above 70 bucks for 5 litres of engine oil since my car never sees the track or hard motoring.
the castrol is a cheap oil. group III base. if you want a good oil you have to pay more for it. it's that simple. the castrol you pay for marketing, motorsport involvement etc, and a bit of your money goes to developing oil, but it's still a cheap oil, and in my view poor value. but again its' a simple equation. good oil costs more than worse oil.
personally I think if you care about your engine and like to give it the old spanking then a IV or a V is the go. I use motul chrono 300V. costs a lot, but to me it's worth every cent. oil is one of the most important ingredients to a happy car. in my mind it's right up there with tyres as the biggest thing people underspend on. I say you can never spend too much $$ on good tyres, or good oil.
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
