Yes have read the first 20 pages or so, then gave up.
1. I did not read anywhere in regards to oil pressure and what it should be.
2. Most posts seem to be from members who may not have alot of knowledge/experience in regards to which is the best oil for a particular car/situation.
It's cool, do not worry.
1. ~2 kg/cm3 at idle ~4 kg/cm3 at 3000rpm+
2. Its been covered. From a technical point of view the ester based oils are superior. Then group IV based oils and then group III based oils.
If you want to know what brands etc.. Then You can't go wrong with motul, redline, royal purple and Mobil as they market their products correctly. The others such as shell, castrol etc state their group iii oils are synthetic when they really are just ripping you off.
hey guys i went out yesterday and bought mobile 1 10w-30 oil, it seemed quite thin and watery, i havent opened it yet just seems to be looking through bottle, i have a rb25det with 115k what u think
I own an R32 gtr and was told from my tuner Paul Fischer who used to work for ADVAN that they used to run 20-60 full synthetic on there big horse power RB26DETT rebuilds for customers. They were the only guys doing so at the time and never spun bearings as the RBs like to do.
I went to Just Jap and got talking with the owner of the joint and asked him about all the oil he sells in the display and he to said that his mechanic is starting to use the 20-60w full Motul synthetic, which they also use in there Targa Tasmania cars.
Only thing is that to do an oil and filter change costs around $145 dollars because it costs $44 per 2litres, so Paul told me to try the Castrol 10-60w full synthetic which i have and so far oil pressure is great and holding well even when driven hard. My Oil pressure gauge on cold idle holds at slightly over the 4cm2 and when hot and driven hard at idle drops to slightly under the 4cm2. I do have also a N1 oil pump though but the pressure is great and safe.
The Castrol cost $65 for 5Lt and genuine oil filter $9.90 from Nismo in Sydney, cheaper yeah but still quality protection and i do this every 3500klms, i drive my car hard and look after it even harder, im fussy but its worth it or maybe because i have a new full forged bottom end with new turbos might be a good enough reason to take of her haha.
Cheers,
Dave.
Edited by GTR 400
Is the oil pressure gauge on the dash accurate in an R32? If so, what are the nominal levels for a rebuilt RB20DET at running temps?
Just rebuilt, so it’s really hard to see the oil level on dip :thumbsup:
Stock gauges are way out, not a very good indication at all..
Guys i usually use Mobil1 0w40 synthetic for my car r33 gtst.. 200rwkw. Ive been doing a few track days and will be doing more in the future.. Am I on the right track with the Mobil1, or you have any other reccomendations?
Cheers.
Ok like many other noobs, yhis thread is stressing me out. So i THINK i know what engine oil i should be using, the motul 8100 stuff. But what about gearbox and diff oils. Beacause both are a little on the noisy and clunky side. Any help??
if its to confusing.. get it from nissan. or take the advise from awell known performance workshop
best in the business. All SAU should buy form him and save.
He said he might be stocking Motul oils soon as well! Also mentioned he might be getting some Castrol synthetic 5w40 (i think it was) that is manufactured in Europe, meant to be pretty good by the sounds of it.
Few questions.
I have an R34GTT with light mods (see sig)
I'm looking to change all my oils (engine, LSD, gearbox)
Engine - Motul 300V 10w40 (6Lt as i have oil cooler)
Diff (This is LSD right?) - Motul 90 PA (2Lt)
Gearbox - Motul GEAR 300 75W-90 (4 Lt)
As for brakes and Clutch, i recommend Motul RBF600 <--- awesome
Does the above seem ok for my use?
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
