Mobil 1 is good, although, i think it's an oil that needs more frequent changes than others...
RB's are "lifty" fullstop. Mobil 1 did quiet mine down a bit, Royal Purple made them quieter again... i would probably stay away from "lifter free" sounds horrible.
Good oil, fairly often. Just stick with that :)
hey Gareth :P, i got it from harold, $11.99 per quart, and you need about 6, $71 - i was just putting it into a more friendly measurement, litres instead of quarts. But it's still around $70 for an oil change
6? Do you have an oil cooler or something? 6 * 0.945 (is that was a quart is?) that would be 5.67 litres.
Anyway, you probably did tell me and I have a terrible memory :laugh:
Yes, I don't like the quarts measurement, its confusing.
hm, i change my oil at 5000kms or less. So non frequent changing is not the problem.
Maybe i try the mobile 1 0w-40w. Without lifter free. Might need to look for an alternative oil tho. 0w-40w fully syn around 90 for 5 litres!
Anyway i inform you guys how it goes. =)
changed oil today from quaker state 20-50w to redline 20-50w went for a drive an heat it up pretty good then on idle started to hear a clicking noise(the kind u hear when u switch off an your exh is coolin down) seemed to be commin from the exh side rocker cover. Car has done 120000km an never heard this before. Any suggestions as to what this might be? By the way its not a constant noise it comes an goes.
yea.. agreed..!
I got told before to use 10/60, buy a guy at repco before...
He said if i used anything lower, my engine would be destroyed............................................................
I smiled and walked off. Lol!
  • 3 weeks later...
Hey guys, Just some feedback on this thread. Took the advice of the blokes here and the mobile one gold 0-30 worked great. Unfortunatly Its too good and I felt the engine was moving too freely and it was to thin.
Now have moved onto motul 5-40 I think xcess 8100 and its pretty good stuff. BTW oil change at 10,000km on the skyline with mobil gold came out slightly deep gold so its good for awhile id say (no oil cooler and yes I gave it a nice run)
Hope that helps some people, I just felt the 0 weight was too thin and would give too much unwanted engine wear.
yeah, Castrol Syntec is their true synthetic oils... and surprise surprise, you can't buy it off the shelf here... well, not that i know about.
I would stick with the german 0w30 though.... i've heard a lot of reports that the American stuff is actually Group III, but Castrol decided they wouldn't tell anyone... :)
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
