Jesus Christ! Just spent half a day reading through all 42 pages of this thread.
I have an R34 GTR and wanted to know what engine oil to use at the next service. It has been getting Mobil 1, but I know there are better ones out there for a premium which I am willing to pay for.
The odometer says 50k but I am not too sure about that - engine is mechanically sound though. It's mainly used for spirited street driving and commuting. My oil temp hardly goes over 90 deg. I am not sure whether it runs rich or not, but I do get some popping noises out the exhaust occasionally - is this mis-firing??. Mods include dump/front pipes, catback exhaust, AFC boost controller at 1.1 max boost, some cam gearing. I live in Melbourne so temp of 0-40deg year round.
I was tryiing to decide between the following:
Motul 300V Chrono 10W-40 (seems to be the most popular motul oil on SAU)
Motul 300V Power 5W-40
Motul 300V Power Racing 5W-30
All three of these have the "double ester technology".
Also on the redline site it recommends 10W-40 for GTRs. I have read redline is good but not as good as the 300V??
Also that the smaller the range the better as there are less additives. As my oil temp usually doesn't go near 100 deg, would then the 5W-30 be better than the others? I am a bit worried that it might be too light a viscosity? But if I'm running rich it should be ok??
Thanks very much for advice. Greatly appreciated.
Edited by Phatboy
wouldn't bother with a 10w from what you're describing. Don't be worried about an 0w or 5w oil
0w30 or 5w30
Redline is better than Motul
there's a group of Group 4 and 5 based oils that is mentioned a lot in this thread, and also a website where to get the best ones.
ye well i have a r33 series 2 gst....and yes its time soon for another oil and filter change.the oil you put in your car is important.and at the end of the day you get what you pay for.and guess what they never seem to throw out the good stuff on specials.like mobile1 0-40 w or motul 0-40w or the less liked catrol edge 0-40w all the good stuff in oils and about say 80 to 90 bucks for 5litres.
yes the mobil1 is good am using it now.lasts longer, i found and doesnt soot up and thin as early.i have mobile1 5-50w and will switch to the mobil1 0-40w for increased performance and fuel economy.so there you go i am even spending for a 0-40w performance iol in my r33 which will only be mainly for cruising and street use.
I believe the Redline and Motul that you've mentioned are more towards performance oils. Don't know which Redline is better than which Motul. You will need to get into the specs for each of them to compare.
Smaller the viscosity range usually has less Viscosity Modifier in it. Meaning it will hold its viscosity more percise and longer than a wider range oil.
5W30 is a bit thin if manufacturer recommends 10W40.
If price is not a concern, I will recommend running Mobil1 0W40 with good oil filter for 5000km OCI for good cold start-up protection with the turbo.
Hope this helps.
5w30 is fine for street use, especially for a R34 GTR. If there is considerable track work, you MAY think about upping it a bit...
Redline = Group 5 based oil
Motul = Group 4 based oil
(and this is in regards to the types of products we would select from these companies)
generally speaking then, Redline is better than Motul
Correct me if I'm wrong but the Motul 300V range is a Group 5 base oil, the 8100 range is a blend of group 4 and 5.
Yeah i was pretty sure the 300V range is a group 5 oil. Personally i have never used the redline engine oils, we sell both motul and redline at work but i always use the Motuls for engine oil and redline for gearbox. What information makes you think that the top of the range redline is better then the 300V? I've had training done by the Motul reps through Link Performance and i'm pretty sure the 300V range is pretty much one of the best oils you can buy in Australia.
Thanks for everyone's advice. Yeah, looked around but didn't find any definitive info that redline engine oil >> motul 300V due to higher group oil.
Both seem good, but I think as PM-R33 said, Motul engine oils are popular as one of the best you can buy whereas redline is renowned for gearbox lubrication.
Think I will stick with the tried and true Motul 300V.... 5W-30 will do the trick I think.
It is good to have someone who works in the industry and has contact to Motul reps.
It would be worthwhile to get some information on the blends of PAO/Easter and formulating composition on their 300V series of engine oil.
It is interesting to see how the Motul AU website has some much descriptive information on base stock oil with no numerical specs whereas ExxonMobil has little to say about base stock oil but quite detail record of numerical specs.
anyone run 10w40 Nulon fully synthetic? any feedback on this oil?
I've got R32gtst with about 130,xxxkms, what do u reckon about those viscoscity?
should i run thinner in winter?
Haven't heard anything about Nulon. It will be good to hear from someone who tried.
Viscosity should use whatever is recommended in the driver manual, it aims for average driver in average weather condition.
You should really start to consider a thicker oil only if it is starting to burn oil because of worn out internal engine parts.
Running a 5W or 0W will help with winter cold-startup.
Hope this helps.
Edited by slidetaker
What do you guys reckon I should use for my r32 gtr... Car has been rebuilt with forgies less than 25000kms ago so is still a fairly new engine. I'm thinking of using royal purple but was wondering whether i should go 5w30 or 10w40? I wanted something like 5w40??? Thought 30 might be too thin...
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
