Sorry Rolls, I should have put a :) or something there. Yeah, in 10yrs on cars I've never seen a tangible performance increase from an oil change. Even back-to-back on a dyno - clean oil is preventative maintenance, not a performance gainer.
Haha I thought so, was just making sure that no one got the wrong idea. :)
On another note something I did notice when I used shell 5-30w was that it leaked quite a bit of oil daily from various seals, the motul 8100 5-40 still leaks a bit but no where near as bad, doesn't burn as much as well.
My car blows smoke if you load it up for the first minute when its cold (I try and avoid this) its not loads of smoke but I can see it from the rear vision mirror. Should I consider going a slightly thicker oil? or am I better off just accepting that its an old motor and will burn some oil and change more frequently?
(Redtop rb20det with apparently 120k on it.)
Edited by Rolls
Idle better?
Do you mean engine quieter?
I've tried so many damn oils over the years and honestly.. never noticed any difference apart from a really really slight difference in valve train noise. When it comes to performance etc its all the same.
i think when you first go from crap oil (ie, "don't know how it came from japan" oil), give it a good clean out, and then put some real good quality stuff in, i think there CAN be differences in idle, noise, lifters, etc...
The 7.5W30 rating came from the Gt-R manual, so I know it is correct....Most RB's have a fair amount of blow by & run rich....
Thanks for confirming these specs. This should help greatly when people are putting in new equiry. Perhaps Durablend 5W30 with shorter interval will be better than a long one with M1 0W40 then.....um..
As to where to draw the line??? All the theories will need to put into consideration in each application. So basically there is no line. Just to give an extreme example, someone could put $5 5L motor oil in a new car if it will be traded-in for another one within a couple of years. The damage is great but is too early to tell. In this case, the $5 oil works perfect for the owner.
Cubes, are you talking about sludging with Helix Utra 5W40??? how many km has it done to start sludging? Was X-cess being used similar for comparison?
I coming to my first servicing of my R34GTT and I've done about 70,000kms.
Been reading up on this oil thread, and im still really confused about oil i should be using. i gathered that motul and royal purple are good brands but can someone help me out specifically as to which one to get and which #W## thing as well?
Most skylines are roughly the same if its for street driving, I'd recommend looking at the first page for a summary of group IV oils and group V oils, they are generally considered the better oils to use.
The lower viscosity the better, so if you can run 0w30 or similar try run that, don't got for something like 10w40 if your car doesn't get really hot (like 105+ degrees).
Personally I've tried Castrol but the American version off performancelub.com, anything besides 0w30 is not German :D
The GTR's recommended 7.5w30 when they came out but oils have changed a lot since then.
If your doing track driving my recommendations will be irrelevant to you as you'd want something with a higher temp...
Castrol SynTec 0w30 (Group III)
A minor mistake in the front page, Castrol SynTec 0w30, the German castrol is group IV. The American 5w40 or similar is group III (sometimes written as III/IV but not true group IV).
Look for posts by Trex101 and khunjeng if you want to read the thread, they are the oil experts :P
Regards,
Gareth
There is alot of factors to consider when choosing oil weight and it's quite difficult to give you any good advice by your above description.
There are 2 major considerations in choosing oil viscosity,
1) Fuel dilution (fuel blowby into oil sump effectively thin down the oil viscosity)
Thicker oil can withstand more fuel dilution then thinner oil but thicker oil also causes friction drag, slower spool, higher FC and more startup wear.
For example: If you run Penrite Sin 25 25w60 in your engine, at 10’c morning when you first crank your engine, you would have effectively run 1131cSt startup viscosity. That’s like 4.5 time thicker then Mobil 1 0w40 (248.8cSt@10’c). It’s like running greases through your engine instead of oil.
2) Engine oil temp
Higher oil temp effectively thins the oil down.
For example: Mobil 1 0w40 is 14.3cSt @ 100'c but when avg oil temp raise to 120'c, it would have thin down to 9.1cSt which mean that it is effectively a 20wt oil (you do not want to run a 20wt oil when you racing down a track, do you). So if your avg oil temp are 90’c, any 30wt oil will do as it is effectively a 40wt oil at that temperature.
The key to the correct oil viscosity depends on mostly the above 2 conditions. There is no one size fit all oil.
Oh, IMO some brand of oil are known to withstand quite abit of fuel dilution before thinning down. Redline & German Castrol is one of them. That’s why it’s highly recommended in BITOG for track or high hp muscle car usage.
Just thought I'd re-quote that for anyone who doesn't understand the oil ratings, I had trouble finding that, it was in response to one of my questions :)
Also there is a discussion of 5w40 Fuchs Synthetic Oil which is not mentioned in the lists here.
What oil would you guys recommend for an R33 gts-t going onto 160,000k's?
Mods (from what I can tell so far, just picked it up a couple of days ago) are: front mount intercooler, bigger injectors, exhaust, fuel pressure gauge in the engine bay?. It also looks like they had to remove some parts to get a RWC to sell it.
Cheers
Cheers
For stock and average mileage, it is recommended to stick with 0W30 or 5W30.
With your engine on higher boost (I am guessing because of the mod) and high mileage, I think it is suitable to run 5W40. Motul X-cess is popular and gives many positive results. Valvoline SynPower is another one that is readily available in most auto retailers.
It would be a good idea to test the condtions of the engine like compression and whether it is burning any oil.
Hope this helps.
Thanks.
I found some Valvoline SynPower, 5w40 (5L) for around $55. Does that price sound about right?
And would this suit (taking into account the k's etc), or would I be better off with the 10w50?
Sounds like you haven't read the thread OR even attempted to read the first page!
Thats not in the list of known quality oils, it *might* be Group III...maybe, if you want quality oil you will be paying a bit more.
5w40 sounds ok for a rating, closer to 0w30 will be better unless your engine gets hot often.
The higher km's idea has been discussed and it was concluded you don't really need to go with a thicker oil as the engine gets older...(at least I think, double check the thread to know for sure)
And that is why I asked :P Cheers.
I don't mean to seem like I have read nothing in this thread, but it's just a bit confusing with 45 pages and everyone's 2c chucked in...
Especially considering the fact that I have only owned a Skyline (also my first performance vehicle) for about 5 days, and I'm just trying to cram all this info in.
SynPower for $55 sounds about right. It is available in Kmarts so watch for auto sales time.
It is mainly Group III, how well is refined I don't know, quality should be similar to those used in Shell and Mobil.
Redline and RoyalPurple is PAO/Esters, but mix proportion, type of esters, additive packages all unknown. These performance oils are double the price of SynPower.
10W50 is a lot thicker than OEM 7.5W30, I won't make such a decision without knowing the conditions of the engine and how 5W40 is working.
Hope this helps.
  • 3 weeks later...
I have an R34 GTT (1998 model) with 63k on the clock and was doing a bit of research on which oil to get and got the impression that 5w30 would be the right viscosity...
But then I just spoke to the garage where I take my car for most of the servicing (Unigroup) and they said they'd use 10W40 and that 5W30 is too thin and doesn't hold the oil pressure too well. And he said to ignore what most people are saying and that as long as I change the oil every 5000km/6months it wouldn't really matter which oil I use.
I'm a bit confused ... 10W40 sound right for a 10yo GTT ? In winter? I think he even mentioned Motul 4100
How about Motul 8100 Xcess (5W40 100% synthetic) ?
Edit: oh yeah this is a daily driver (mostly city) with no track/racing.
Edited by Delta Force
then ask the garage why my oil pressure was/is always fine when running 0w in summer :P they learn the same old shit at those mechanic schools... old shit... :D
10w40 if you're doing a lot of track work.... PERHAPS....
I went to 5w30 BECAUSE i was doing some track work (Royal Purple) but will drop down to 0w30 German Castrol to see how that goes.
98, GTT, 76K km
I changed oil at 5000km's. The Motul was used in exactly the same style and km's of driving.
At first I didn't believe it so I repeated the test with the shell and again sludge in the oil filter. Not all that happy to be honest as I would have liked to run the shell as its a fair whack cheaper @~$45.
I've ran motul for a few oil changes since so I may try for a third time with the shell just to be sure.
This information kindly provided by Rolls, some_cs_student, & trex101
When choosing oils the better the rating, generally the better the oil, and also the more expensive. Keep in mind even the Group II oils are probably still better then any oil that was made when your car was manufactured.
Basic explanation of ratings
Group I - mineral
Group II/II+ - hydrocrak (VI below 120)
Group III - hydrocrack (VI above 120, mineral derive "Fake Synthetic")
Group IV - polyalphaolefin (man made Synthetic)
Group V - Ester & other un-group fluid (Ester or Polyolester, super high grade Synthetic, good for aircraft jet engine).
Common products and their ratings.
Redline (Group V Polyester)
Motul 300V (Group V)
Motul 8100 E-Tech 0W40 (Group IV/V Blend)
Mobil 1 (Group IV)
Motul 8100 xcess 5w40 (Group IV) ~$59 - one of the best value
Castrol SynTec 0w30 (Group IV) [A minor mistake in the front page, Castrol SynTec 0w30, the German castrol is group IV. The American 5w40 or similar is group III (sometimes written as III/IV but not true group IV).]
Castrol Edge Sport 5w30 or 10w60 (Group III)
Motul 4100 Turbolight (Group II?)
Keep in mind that the 100% synthetic stickers mean jack, just means that the oil is at least Group III. As far as viscosity ratings go, this depends entirely on what temperature range your car is going to be used in and your driving style (track or street car) A decent read through this thread should help you answer that.
As far as oil filters go, get a genuine nissan one if you don't want to spend much, these are superior to ryco/cooper.
On Selecting Which Viscosity
For example: If you run Penrite Sin 25 25w60 in your engine, at 10'c morning when you first crank your engine, you would have effectively run 1131cSt startup viscosity. That's like 4.5 time thicker then Mobil 1 0w40 (248.8cSt@10'c). It's like running greases through your engine instead of oil.
2) Engine oil temp
For example: Mobil 1 0w40 is 14.3cSt @ 100'c but when avg oil temp raise to 120'c, it would have thin down to 9.1cSt which mean that it is effectively a 20wt oil (you do not want to run a 20wt oil when you racing down a track, do you). So if your avg oil temp are 90'c, any 30wt oil will do as it is effectively a 40wt oil at that temperature.
Oh, IMO some brand of oil are known to withstand quite abit of fuel dilution before thinning down. Redline & German Castrol is one of them. That's why it's highly recommended in BITOG for track or high hp muscle car usage.
I did read this, and other post's on this topic.
This is my situation, i have a standerd rebuilt s1 rb25 (5000km old) Just did a track day. temp at track gets about 105 atm (will be sorting this out soon). sprited driving in the hills see about 90-95.
In example 2 of the above quote, it talks about oil thinning at higher themps...... i dont quite understand what im needing to use at these temps.
Also, what should a warm s1 rb25 oil pressure sit at when idleing? i have a apexi oil prerssure gauge, but am un sure of whats good and whats not
EDIT: After further research, i have came accross some spec's on oil pressure that say the following
RB25det KG/CM2 (bar?)
Warm engine**
Idle 1.1 kg/cm2
2000rpm 3.5 kg/cm2
6000rpm 5.6 kg/cm2
Edited by 1SLP80
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
