Its more the point of why buy a crap so called 'synthetic' grpIII oil when for the same price u can get another brand that is based on the 'better' grpiv.
I run the Motul 5w40 for $59.
Beats the crap out of the Castrol 5w30 and Shell 5w40 of which are grp3 based and strangely my motor appears to use a little oil each change at 5k. The Motul 5w40 or Mobil 5w50 it doesn't use a drop. Interestingly they are both grpiv oils.
The fact that he/she is changing at 5K intervals does negate part of the problem, assuming he doesn't change his oil filter every 5K with it, but there are better oils out there.
However, I just disagree with the "ask your local autobarn for there recommendation" when we have a huge discussion and a summary of the oils in the first post.
There's been plenty of effort to guide people on what oils to buy, I'm not an expert but at least I've researched my opinion.
I run 98 octane fuel only in my Skyline, its what its tuned for.
I just dont see any concrete evidence about which oil is better than another apart from these used oil tests (no I cbf sifting through 48 pages to look for them either), fyi I did read this thread and some of the associated links before I selected the oil I was going to use, even Mobil 1 oil is around 80 bucks a bottle for 0w/40, and I use more than 5 litres of oil in a service (due to the bigger sump).
Not all salespeople are clueless morons either. I know of 2 guys who work at different parts franchise shops here who are Skyline owners and very knowledgeable.
The main reasons I ended up going with the Castrol were the fact that several mates use it in their Skylines which do get driven hard regularly and over a long period, and my parents have always used it in their RB30 Patrol which has just gone over 400 000km and still running fine, which suggests to me that it cant be as bad as some of you are making out.
The one and only time I've seen oil make a performance difference was when a local performance mechanic gave me a demonstration of an LS1 running Pennzoil 5w30 on a dyno, which then had the oil immediately changed to Martini 0w40 IIRC for a 3rwkw gain. Therefore if I were to try anything else it would be that first.
Btw, what is wrong with changing the oil filter at 5000km?
Technically, for 5W30, Motul X-max(5W30) has a closer viscosity than X-cess(5W40). There are also Mobil1 5W30 silver bottle silver cap that I have seen around. So there are heaps of choices. Not just Castrol....
I see no advantage in using higher quality based stock oil if a person is doing 3 summer months, 5000km OCI driving in grandma style....
So there is no good or bad oil, just depends on your application, OCI, driving style, weather conditions....
The average skyline isn't driven grandma style. The grpiii based oils I have tried all have been consumed slightly by the motor. The grpiv oils however not a drop.
I am just exaggerating, I am sure you understand what I am trying to say.
In terms of oil consumption, that's a perfect example. If you find out that with the conditions of your engine and your driving style, Edge Sport did seem to be burnt off more than X-cess. That X-cess is perfect for you.
P.S. personally, I think oil consumption have more to do with viscosity VS oil pressure and add packs than based stock oil.
I can agree with cubes, in my mildly tuned r34 the motul xcess 8100 5-40 has really improved the way the car runs.. It doesnt burn almost any oil, in my last 3 changes. However i have seen a drop of oil leak say every week.. Wondering if a move to a 10w-40 would help the slight leak..
However all in all the xcess 8100 has really tested itself- i find it stays golden till about 4000kms and then starts to slowly go darker so by 5000km it looks dark. Great oil for the money :D
i'm going to try the martini oil then the motul just to satisfy myself to see if there is any difference compared to the castrol.
Now can anyone shed any light on whether Redline Shockproof Lightweight is really any good for going into a Stagea manual box with a noisy 4th syncro, or am I better off just getting any synthetic 80w90?
...doesnt burn almost any oil, in my last 3 changes. However i have seen a drop of oil leak say every week.. Wondering if a move to a 10w-40 would help the slight leak..
If it is just a drop every week, I would not worry about it. You could try to trace it so you know exactly where it is leaking from. Probably just some bolts and nuts not tight enough.
The RB30 is a forklift motor so that probably explains a bit. :blink:
I did not split the oil filter open with the castrol 5w30 but with the shell 5w40 i found little lumps of what looked like grease.
I then ran Motul.. no sludge in the filter.
I switched between oils a few times. Everytime the shell stuff deposited sludgy lumps in to the filter.
Maybe thats where the 5w40 Shell was burning/sludging off too :D
There is sludge and vanish build up in the valvetrain area and then there is sludge like material clogging the oil filter. I believe they are different, just think about the temperature different between these two areas.....
Then there should not be a relation between burning (oil consumption) and sludging..
Burning will likely leave carbon deposit in and around components of the chamber...
Sludging are more due to high heat and baked-dry up oil....
Don't know may be someone who have more experience can chip in.....
Definitely. I was a little misleading stating consumed when in fact it was being caught in the filter as slight sludge.
The motor has been rebuilt, always had regular oil changes. I can't comment on the bottom end but the top end and cam covers are super clean inside.
Hey guys new to SAU and have just brought a 93 r32 gtst with 121xxx km's which is stock standard.
Im wanting to do oil changes for engine, gearbox and diff. After reading the post think i've decided on motul 300v but still not 100% sure for the engine but have no idea on gearbox or diff oils? also how much oil does engine, gearbox and diff hold? Prices and avalibilty isn't a problem as i work at the local repco store but would rather take advise from you guys/girls because repco only know holden/ford best lol.
thanks.
^ rb25 takles around 3.7-3.8 L of engine oil.
diff is around 2L
and gearbox is around 2.2L
does anyone know whats a good & recommended fully synthetic oil for a neo rb25de ?
cheers
my 34 takes 5 and a bit litres of engine oil, not sure where you're getting 3.7 from?? :rofl:
does anyone know whats a good & recommended fully synthetic oil for a neo rb25de ? have you read anything in here??
my rb26 has over a 100k on the dail whats a recomended oil, sumthin with a lil more thickness to it???
No, as per previous discussion in the thread you do not need to buy thicker oil as the engine gets older.
apprently 10w-40/15w-40 is recommended for RB's?
narrowing it down to these 2..
Penrite Sin oil 15 15w-40
elf competition GT 10w-40
currently using mobil 1 syn-s 10w-40 and afaik isn't available anymore & has been replaced with another name, mobil 2000 or something.
gonna change to fully synthetic to either one of the above mentioned ones.
car is due for a change in a months time so see how it goes then.
ive read that with the full synthetic oils, they still stay the gold colour after 4000km.
with the current oil im using, it starts to change colour after 2500~km, im guessing the oil im using isn't that good?
any opinions with the 2 oils ive chosen ?
wheres the cheapeast place in syd to get either of the 2?
cheers
Edited by dori32
hey guys....what would be the best oil for a noisy rb manual gear box.. i know ive ogtta get it rebuilt soon.... but gotta hold off until i have the coin... is there any oils ( i think thicker is better ) to quiet it down a lil?? cheers
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
