i have the nissan r33 manual here which was converted from japanese to english.
in the service data it says
"when the vehical leaves the factory, vehicials contain 7.5W-30 (SG) oil..
so im guessing anything around that be fine yeah?
yeah more or less around that number
fully synthetic oil would be good as well..
If u have doubts just get mobile 1 0 - 40... i can assure you from my understanding they are 100% fully synthetic...
tho the price of them isnt to b laughed at.. 70-80 per 5 litre depending where u buy it from.
mobile 1 is 100% synthetic but its a handmade synthetic so its only a group 4 oil because the synthetic quality isnt that of a group 5 (Redline or Amsoil). If you want a good oil redline 10W-40 is the best stuff for a skyline. 7.5W-30 will be blown out your skyline in a few weeks because simply we do not live in japan so the oil runs at hotter engine temperatures and there for just to thin for it to stay in, i warn you if you go that thin it will blow it out.
I'm running 0w30 right now, it has not "blown out" of my skyline. Slightly modified GTR (250rwkw) with oil cooler and temperatures stay below 80 degrees constantly, usually 70 except during spirited driving.
I'm considering trying Winton with the 0w30 to see how it goes on a track...
Without the oil cooler it should be ok for the street but 5 or 10w40 if your worried.
EDIT: for above poster, once again (its probably in the first post) http://performancelub.com
Group 4 oil is more then high enough for a GTS T that is driven on the street 90% of the time and 10% of the time having some fun on the skid pan.
If u getting serious in track days etc and pushing the car then i would probably use a group 5 oil. Otherwise you would be wasting the extra dollars your spending on redline... more so if you are like me and changing oil every 5k.
  • 5 weeks later...
I use the nulon product 10w40 http://www.nulon.com.au/products.php?produ...wing_Engine_Oil, i use used it in my subaru, evo and gtr and never had a problem with it. oil pressures ramain good, engine runs quite and i have never burnt any in any off my applications.
cost me $60 with a ryco filter...
really good value if anyone wants a quility oil with out a mega price tag.
would be interesting to see if any others are using it atm.
Edited by el capitan
i have recently finished rebuilding me engine (RB25DET) and have just finished running the engine in and about to do a oil change.
I have been told to use any 10-30w oil. Was thinking of using Motul 4000 Motion if that's the case? Is that the right type of oil to be using after a rebuild or should i move up to the Chrono?
They don't make Motul 4000 Motion any more - i've been using 4100 Turbolight 10W-40 in my r34 - excellent oil pressure even when i've thrashed it around qld raceway at a track day last month - same oil in there now and the oil pressure is still THE SAME!!! pretty damn good for a semi-synthetic! if you want a better option try 8100 X-cess 5W-40 100% synthetic (used this one before too - bit more expensive) or 300V chrono 10W-40. if yor engine is freshly built and not run in DON'T USE ANY SYNTHETIC OR FRICTION MODIFIED OIL!!!! :) it will stop your rings from bedding in properly (because of the firiction modifiers) and cause the engine to basically be in the same state as if it were badly worn! once the engine is properly run in you can dump the running-in oil and put the good stuff in! :rolleyes:
sounds like motul seems to be the go....
i got a rb20det and i run royal purple 10w40 in her she goes all right bit on the expensive side at $80 bucks for 5L though and doin a change at every 5000k they reckon you can get 10000k out of it but not sure whether to leave it that long
royal purple is good shit
if ur using 300V, RP or Redline i would be leaving it in for approx 10,000kms if its just general use. The addatives take time to work.
Actually Amsoil is also a Group 4 oil as stated in an email I received from one of their Lubrication Specialists;
"Group IV -Chemical Reactions: Group IV base oils are chemically engineered synthetic base stocks.
Polyalphaolefins (PAO's) are a common example of a synthetic base stock. Synthetics, when combined with additives, offer excellent performance over a wide range of lubricating properties. They have very stable chemical compositions and highly uniform molecular chains. Group IV base oils are becoming more common in synthetic and synthetic-blend products for automotive and industrial applications (hh)."
"AMSOIL uses only Group IV PAO's"
Not quite sure you reasoning on this one.
"Genuine" Nissan oil that is used for car servicing at Nissan Dealerships is a 5W30.
I don't see too many Nissan's driving around blowing out oil.
My mate had his NM35 Stagea serviced at a Nissan dealership (inc oil change) and he certainly is not "Blowing oil out"... and yes, he loves boost :)
Oh yeah, currently I am using Motul 300v Chrono (and have been for the last 46,000kms) but will probably be changing to the 300v Power Racing (5W30) next service.
I change every 10,000km's, and have been using either K&N or Amsoil oil filters.
Runs quite nicely! :D
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
