i got sougi s6000 for 65 bucks at auto barn today in warners bay newcastle. just go in and say i can get sougi s6000 from spares planet for 65 bucks. else if you live in sydney go there and get it. i bought 2 bottles to give it a go
Can anyone see any dramas buying / running this product. Parallel import from the USA. Does it make any difference?
http://cgi.ebay.com.au/Mobil-1-Engine-Oil-...=item27aff2f3e1
Autobarn etc pricing is $95 for 5l and this stuff is $65 (plus freight) for 5.68l. The only (non technical) down side I can see is the packaging not being in litres to slightly harder to know what's gone in - I'm really scratching for problems now....
Advice?
I just put in the sougi s5000 this arvo, didn't change the filter though, was too lazy, will change the filter next service..
With the previous oil, when i ran the car, it didn't sound good, revving above 5.5krpm sounded rough..
With the new oil, i did some revving in neutral, nice and smooth, i like it, for under 50bucks, its a damn good oil, and at this price, i can change it every 4000kms. Driving around felt nice and smooth, but the exhaust was a tad louder...
LOL freighting a single bottle of oil from the USA is going to cost like $100
edit: oh wait it is local, in that case I cant see any issues.
looks dodgy as hell that listing on ebay! looks like the inside of a shipping container
probably is, but how else does the oil get here?
Worry not as in the end I bought from performancelub.com. Same product and pretty much the same price, just a more forum-known seller. Plenty of feedback on the eBay seller too though.
http://www.motul.com.au/product_line_up/4s.../4stroke16.html
Is there any reason as to why this would not be suitable for a car? It looks like it's aimed at motorcycles, but it isn't specifically for wet clutch or integrated gearbox....just a 4-stroke. It's 10w40, so it would be great as I'm after a 10w40 oil. Thoughts?
Most bikes have a wet clutch, what this means is the clutch shares the engine oil. Bike oils don't have any friction modifiers in them, otherwise if you put normal car oil in the clutch would be too slippery and never grip.
Wouldn't have anything to do with him putting two zillion PSI through it ?? nah that wouldn't count :banana:
Changed my oil in my 08 wrx (35,000ks). Used motul 300v 5w30 power racing, $60 for 2 litres (lucky my car only uses 4, unlike the gtr which used close to 6 with alll the external lines and coolers, cans etc). Very happy with the results. The car seems to rev easier, sound quiter and accelerate smoother. Who would have thought such a difference could have come from using a better oil. To be fair though, the Subaru service centre were using a 5w30 semi castrol, so one would expect such a difference.
Does anyone know the current state of GW and Sougi? I havn't posted here in quite a few months and was wondering if anything had changed, or if they went through with their plan to stop production. Birds? Galois? you guys are still here I hope :P
Hey there,
just offering some feedback as i recently purchased some Redline ATF from this guys and it's legit, for the same price as Harold's @ performancelub.com
plus he also stocks 1 Gallon variants of the entire Redline Range as performancelub.com only offers the 1L quart bottles
I chose to pick up from him, but shipping is under $10 up to 25kg, so for NSWelshmen its great if u want to save money by picking up rather than getting it posted
he's a decent guy, service and price was good so its hard to choose other wise if you're after Redline, Mobil or Shell fluids. He also stocks Mobil oil filters and NGK sparkplugs
Here are his details,
GL lubricants
Nick
0405 509 621
Advice?
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
