Advanced Engine Management (Wolf) have a "black box" solution for this problem. Maybe Microtech have one too.
I'll try and remember to check mine out tonight and let you know how the Wolf box works.
  • 3 weeks later...
  • 2 months later...
well after plugging in a manual RB20DET ECU into the original loom last weekend, the car spluttered and died, seemed to be the fact that its still all fully wired up, I am considering cutting all of the wires apart from the TPS and power wires, though I'd really like to not have to do that, so has anyone else found an alternative yet?
  • 3 months later...
ok well after Googling this problem, and coming back to a similar archived thread on here, I decided to link the throttle opening output and throttle sensor output signals together to try and get the TPS voltage to the ATTESA computer - when turned on, the light went out for one second and came back on.
Do I still need this buffer circuit as well, or should I try a diagnosis on the entire system in case there's something else wrong?
Edited by bozodos
well after several hours of digging around in the archives, I found this quote from TO4GTR in another ATTESSA thread regarding a Microtech.
"yes after many headsrcatching sessions.
hears what it was all about.
tps adjustment to get .4volts
hooking up the attessa throttle wire to the microtech throttle signal.
unplugging the f**king air bleed conector"
the TPS wires mentioned in the Microtech manual are grey and brown, and on the wiring diagram, it has TPS 5v and TPS Sig pinouts, though I'm not 100% on which to use, im guessing TPS Signal to TPS output on the original loom.
Edited by bozodos
Just attempted connecting TPS output from original loom to Microtech TPS Signal wires, STILL no luck!
can anyone PLEASE help me on this one - there must be at least one GT-R out there with both a working Microtech and ATTESSA system!
Hello I am researching the same issue for an ECU install.
So Far I have;
The ATTESA requires 0.4V to 3.5V TPS signal
The factory ECU has an inbuilt amplifier that generates the required signal.
When using an aftermarket ECU, that does not offer TPS out, the RB26 wiring loom requires modification to the wire connected to pin 56 TPS output signal. The wire at pin 56 needs to be cut off and T connected to pin 38 TPS input signal.
The TPS sensor needs to be manually adjusted to provide 0.4V when idling with the throttle closed.
Your Microtech should have three wires connected to the TPS
Ground
5V power
TPS Signal (connect to Microtech and ATTESA)
I have not tested this option, but provided my research is correct, you need to connect the wire that was originally connected to pin 56 to the TPS Signal wire on the Microtech and adjust the tps until it reads 0.4V at idle with the throttle closed. I beleive the ATTESA also requires an RPM signal which is generated by the factory ECU at pin7.
I intend to build a simulation amplifier and will post the design once complete
Edited by bradkazz
Yeah I've already adjusted TPS at idle to exactly 0.4v with a multimeter, and then tried alternately connecting wires 56 and 38, then connecting wire 56 to the grey TPS signal wire on the Microtech - the other thing I should have done was pulled out my subs and amp and checked the error codes being thrown up by the ATTESSA computer to see if there was something else wrong with the system. The part I'm still unsure about is whether it definitely needs some sort of extra circuitry or whether joining the wires is enough.
(when I bought this car I was told that the standard computer need only be piggybacked onto the Microtech, stupid me for not getting the previous owner to test this out)
From what I have read, once the idle voltage is adjusted to 0.4v the Attesa will function, but becuase the ramp rate is not exactly as expected the system will apply more front bias at a lower throttle opening. An additional circuit should not be required, but it would make the system function exactly as intended.
Perhaps your issue is related to the tacho signal.
Some of the post I have read indicate that the ATTESA and ABS also use a tacho signal, the factory ECU outputs a tacho signal from pin7. I assume you will need to connect the Microtech tacho out to this same wire.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
