the engine is back up for grabs, because the person cancelled any offers for the engine
now the engine im selling is
RB20 turbo (153xxx)
NEVER been boosted or modified in anyway
the item includes
engine
turbo
manifold
AFM( just got changed for $370)
stock airbox (no cop problems)
looms and wiring
coil pack
and plenty more (basically everything under the bonnet)
give me a price and i will tell u if i sell it
i will still sell the whole wreck for $2500 not negotiable its very cheap. it normaly can cost more than $4350 in parts if sold bit by bit
  • Replies 90
i got the back bumper for sale $200, it cost me $350 and it has just been painted and its basically brand new
any one wants the whole wreck for $2200 let me know thats the cheapest i can sell it for and thats very cheap with engine and all
  • 4 weeks later...
ok guys, my car is on ebay for 1500 minimum bid if u want it its so cheap its not funny how ever ill sell it for $1650 just because i wanna get rid of it any offers welcome but as i said minimum $1500
well u can get it from a few stations in melbourne i think u need to do ur research b4 u post ur message
I have never seen a shell that doesnt sell v-power. Why dont u just sell it for parts if u think you can get 4 grand?
Mate, Every single station sells it, its just 98 octane. I can think of 3 stations in Melbourne and I dont even live there.
http://www.shell.com/home/content2/au-en/s...nformation.html
There is V power and V power racing.
V Power racing fuel is being phased out and it is different to V Power and isn't at every Shell station.
depending on how long the car's been sitting around crashed for the V power Racing has probably gone stale making it now less octane than normal V Power...
if you want you can pay me and ill take it!!!
Then got the the wreckers if he want to sell the whole thing then he wont want to rip one part off it
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
