you couldnt comply it the mods are too structual.
and its a rwd nonturbo model with a manual rb25 turbo
u could just buy a stag and have it done here. im sure any place that does 4wd cut downs could handle it. b4 any1 says it, yes i am aware 4wds have a separate chassis. but it shouldnt matter, they will still know what there doin. come to think of it, years ago (pre holden crewman days) i heard of a company cutting down commo wagons into duel cabs.
https://www.sau.com.au/forums/topic/224617-ute/page/2/#findComment-3959812
  • Replies 42
a guy I met in brissy did combi van to ute conversions and engineers em to be road rego'd. I'm sure it can't be impossible. granted being an old car it doesn't have to comply to a lot of ADR's.
https://www.sau.com.au/forums/topic/224617-ute/page/2/#findComment-3959849
Nup - you are talking about the New One Tonner co out of Adelaide, they had to get all their vehicles engineered as ICV's, and it was done by mounting the front half of a commo on an old one tonner chassis. There is no way in hell you would get something like that rego'd here. If you want a close to home example, just look at what the Osman brothers went through to get rego for their WRX ute (and that was a domestic market car that already complied with current ADR's)
As for the kombi to ute conversion, why the hell wouldn't you just buy a factory kombi ute? They came in single and crew cabs from the factory.....
https://www.sau.com.au/forums/topic/224617-ute/page/2/#findComment-3960075
there are plenty of sedans around that have been registered after having the roof chopped off to make convertibles. a few extra chassis rails for strength before the chop so it doesnt all coolapse sheet metal the cab in and add a window then fabricate a drop in rear tray and after a few thousand man hours u might have one.
https://www.sau.com.au/forums/topic/224617-ute/page/2/#findComment-3960595
A stag ute is such a brilliant idea would be a great project if you had some automotive engineering experience behind you. Im sure if you did the conversion here then had it done right with all the right parties happy you'd be able to register it. Would be a ute muster favourite fo sho!!
You could even make it have a tail gate with enough work
the red one has a drop down tail gate
https://www.sau.com.au/forums/topic/224617-ute/page/2/#findComment-3961336
love this one its the background on my comp at work..
got this stag on my comp at home tho.
ow and sorry bout the double thingo lol wont let me delete it ehehehehehehehehe
Edited by messanic
https://www.sau.com.au/forums/topic/224617-ute/page/2/#findComment-3962477
Check this out for ute conversions. A friend of a friend owned this car from new paided approx $260K for it with extra's and then sold it to Stuart Appleby (the golfer) who gave it to a shop to convert it to a BMW M5 ute. Check out the attached site. Great detailed pictures of the work involved. Massive effort!
http://www.m5ute.com
https://www.sau.com.au/forums/topic/224617-ute/page/2/#findComment-3964644
Wow!
That is a dead set work of art! SOOOOO much work involved in a project like that. A crapload more than converting a wagon, thats for sure.
It will go like a scalded cat with the M5 engine too.
https://www.sau.com.au/forums/topic/224617-ute/page/2/#findComment-3964926
Nup - you are talking about the New One Tonner co out of Adelaide, they had to get all their vehicles engineered as ICV's, and it was done by mounting the front half of a commo on an old one tonner chassis. There is no way in hell you would get something like that rego'd here. If you want a close to home example, just look at what the Osman brothers went through to get rego for their WRX ute (and that was a domestic market car that already complied with current ADR's) As for the kombi to ute conversion, why the hell wouldn't you just buy a factory kombi ute? They came in single and crew cabs from the factory.....
no. im talkin about vt-vx wagons cut into dual cabs. they did a feature on them in st comm magazine. if i can find the article i'll post up the info. i got like 150 magazines to look through. will take a while
Edited by Raysboostin
https://www.sau.com.au/forums/topic/224617-ute/page/2/#findComment-3968582
  • 4 weeks later...
ok, its official
once the stag is thrugh Shakken again (inspection) this december, me and 3 other friends are gonna ute my stagea.
Im using an extra tailgate to make the wall of the cab, and then sheetmetal riveted and welded to box in the back.
we are still in the design stagea of course, but its a go
https://www.sau.com.au/forums/topic/224617-ute/page/2/#findComment-4023948
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
