Why are people continually getting sucked in to buying packaged
splits?
Heres what I have done for my home and my car and the results have been excellent.
I have bought various drivers like Focal or scanspeak, typical high end home audio stuff and have used them for my home audio and car audio.
I've seen these drivers feature in home speakers of more than 15k.
Nothing can compare to the SQ you get using these top of the line drivers. The only difficult part is putting the crossover together, but if have played with Lego before you should be ok.
Ask mum first before using the soldering iron :)
