Other thread got closed so for those interested the seargeant has removed my yellow sticker today after he recieved a copy of my letter.
So there you go, if you get a yellow sticker that is GENUINLEY wrong such as defects listed that are not realy defects (check with pits first if you are not sure) do the following things:
Call the station where the officers who have given you the yellow sticker are based and ask to speak to the officer in charge of them and explain your situation. If that fails:
Write a letter addressed to the officer in charge of which ever department gave you the yellow sticker explaining your situation and make sure you send it via registered mail. Make shure that you put the following line somewhere in it: "I do not wish to make a formal complaint against the officers at this stage as I hope to resolve this matter without the need for one"
And the most importaint bit is never abuse anyone, if you do your chances of getting anywhere dissapear fast.
So there you go, sometimes these things can end well :laugh:
https://www.sau.com.au/forums/topic/224674-yellow-sticker-conclusion/
Seargeant called me today and asked if I could come by so he could have a quick look at the car (I listed my phone number in my letter as one of the means I can be contacted by), he glanced over all the things that were listed as defective on the sticker notice and took the sticker off. Had a chat to him for a while, realy decent guy actualy
Congrats buddy! I bet you're relieved! Did the officer end up giving you some kind of explanation as to why he was "unhappy" with the previous inspection? It's so rare, hearing about officers removing defects that they've issued...big win!
Again, well done! :laugh:
The seargeant who removed the sticker was the seargeant in charge of the officers who issued me with the sticker. Havent seen or spoken to the officers who gave it to me in the first place since the incident so no explanation given, it realy does not mater though, by removing the sticker they admit wrong doing so thats that.
Im just happy its over with without me having to fork out more $ this time
i was a little irrate when the last thread was deleted, but glad to hear it worked out.
now back to the qld section for me
after i peruse your for sale section :geek:
will be in perth shortly, so may be able to pick some stuff up.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
