R33 Series 1 Wrecking In Sydney, Loads Of Aftermarket Bits
Howdy, i've got a S1 r33 gts-t here thats taken a big hit into the passenger door/rear quarter, so it's up for wrecking. Has lots of aftermarket stuff!
Contact me via PM or post in this thread if you're interested in anything
Series 1 headlights, great nick - $350
Fiberglass mesh grile, slight damage - $50
A/c condenser - $150
A/c thermo fan - $50
Radiator reo/nose cut - $200
Guards - $100 each side
Black S1 bonnet - $220
HKS pod with hks afm shaped pipe $100
GTR fuel pump in Gts-t cradle - $100
Fat rear swaybar - 25/26mm - $100
post-35556-1213865613_thumb.jpg post-35556-1213865514_thumb.jpg post-35556-1213865689_thumb.jpg post-35556-1213865781_thumb.jpg post-35556-1213865556_thumb.jpg
Greddy/trust T67-25G turbo, highmount manifold, 3" dump/front pipe to suit, Greddy external wastegate w/ screamer pipe, oil lines included
$2000 ono all together. pickup only!
Rays wheel nuts (black) + locknuts/key - $100
Rays "mazdaspeed"? 17" wheels. fronts 235, rears 255 with abit of dish - $1000 ono
Tyres are bridgestone potenza Re-01, has heaps of tread left- ~80%. unfortunately one of the tyres has a small screw in it, but it still holds pressure fine
Recaro drivers side seat with rail to suit r32/r33/r34 - $550
HKS twin plate clutch with flywheel to suit - $700 ono
HKS 3-3.5" catback exhaust, sounded awesome - $350
clear side indicators - $50 posted
Greddy type-S bov - $120 with r33 adaptor
Greddy turbo timer - $60
HKS EBC / EVC - $350 ono
HKS Fcon-V pro v2.1 - $400
tomei brake cyl stopper - $90
HKS electronic gauges, 3x temp gauges (exhaust, water and oil) Boost gauge, and oil pressure gauge. Comes with all wiring - $120 each
TV/DVD player with 7" TFT screen (double din player). Plays cds, dvds, radio and can also display free to air TV with the right aerial - $450
Pioneer 6/6.5" speakers - $50
Greddy front mount cooler with most of the piping included (uses standard piping holes) - $400
Zeal/endless coilovers- height/damper adjustable. unfortunately bushes at the bottom are shot, and i think the front drivers side has a leak - $offers
Adjustable castor rods - $150
GET adjustable front upper control arms - $150
Stock parts:
Rear strut brace - $100
S2 AFM (pink sticker) - $110
Instrument cluster - Sold
Climate control unit - $60
washer bottle - $20
radiator overflow bottle - $20
fuse box cover - $20
Ignition barrel + key + door barrels - $120
Stock cat - $40
Stock dump/front pipe $50
charcoal canister - $40
Stock airbox snorkel - $40
Space saver - $50
Castor rods, good bushes - $80
Front hubs- $80 each
Front lower control arm, drivers side only - $70
Front calipers - $300
Rear calipers - $160/pair
Rear lower control arms- $70 each
handbrake drum assembly + cables - $180
stock diff, good cond - $200
driveshafts - $60 pair
complete rear cradle, disc to disc (minus calipers) - $500
Drivers side window switch, 100% workin- $100
Drivers side window motor - $100
Complete set floor mats, genuine nissan - $140
S2 door trims - $60 per side
centre console - $60
seatbelts & buckles, full set - $100
rear view mirror - $30
headlight & indicator stalks - $40
electric aerial $60
Postage can be arranged at buyers expense. Pickup only on the bigger stuff, located St. george area in Sydney
If you're after any little parts not listed, PM me!
Cheers!
  • Replies 45
hi.. is the washer bottle come with the pump..
also will the pump useable on r34..
is so i take it..
thanks
Yep comes with both the small pumps. not sure if they fit r34 though. if you get me a picture of them i'll check
is the hicas/power steering computer avail?
You have PM regarding BOV
pm replied
I will take the tomei brake stopper if it will fit a R33 GTR.
Anyone know if this will fit? pm sent
pm sent for recaro
replied
i'll take the HKS computer mate , u got PM on a whole heapa gear!!!
no worries, pm replied
Few things are sold pending payment!:
greddy bov
HKS gauges
HKS fcon-V
rear strut brace
hi, interested in getting the front mount and the clear indicators, just want to know whether the intercooler includes the required piping to connect to the stock intercooler piping as i want to retain the air box. also will it fit behind the stock s2 front bar? what if any modifications are required to fit it.
thanks
pm sent
replied
thanks
Sorry mate looks like it's sold at the moment, pending payment.
bloody pickup only
Changed my mind about not posting the turbo parts if thats what you're referring to, can't bloody edit my post. Pm sent
PM sent again.
Sorry mate missed yours before. replied
Some more parts sold pending payment:
greddy fmic/piping
clear indicators
i sent a pm about the clutch
replied
Can yu find out how much to send the clutch to Qld 4680
yeah mate i'll let ya know
hi are the blinkers still for sale and has the intercooler been sold as i am wanting to buy it.
Sorry dude, blinkers and fmic sold this weekend
engine for sale? i know a guy in sydney who needs one
Yeah it could be for sale, the compression was a little low so i'm thinking of stripping it. i'm pretty sure its got a thicker headgasket, but 6th cyl was a little lower than the rest (1,2,3,4,5=135psi, 6=125psi)
would he be interested?
Hks gauges sold
greddy fmic sold
nismo clear indicators sold
GTR pump sold
greddy bov sold
 Share
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
