tailshaft to suit as well, im not 100% sure but the RB20 one might do,
everythings pretty much plug/bolt in and play.
pretty straight forward to do yourself over a weekend.
if theres anything else someone else on here will pick up on it lol
to make things easier try and find a manual block with the gearbox attached. correct me if im wrongbut there are slight differences in block size between autos and manuals. itl just make things easier...that is presuming you want a manual...
and going by the laws of physics, unless the RB20 and RB25 tailshafts are the same, an RB20 tailshaft wouldnt be able to handle the increased torque from the extra capacity from the 25 for long before snapping :S
hang on, wait what?
is he manual converting it as well or...?
i'd just leave your gearbox in the car, just out with the old engine and in with the new, change the clutch while your at it t5o somthing a bit better tho. The tailshaft is same afaik, and the rb25de doesnt really make much more power than the 20 anyway, and people get away with turboing them (or dropping in turbo donks) with no issues.
Sorry guys, I should have been more detailed.
Car previously had an RB20DE in it with manual gearbox.
Car now has no engine or box. It still retains the loom.
I'm going to hunt around the traps and see if I can find a Series 1 RB25DE without VVL, as I don't really want the associated wiring headache of the VVL function.
a small number of R32s came from factory with the RB25DE. it should be a walk in the park.
the R33 RB25DE uses an R32 RB20DET gearbox so I don't see much of a problem with mix-and-matching - and agree with skit.
no worries. Since the box is already out, you may aswell bolt it to your new engine and put them both in at the same time, make things easier.
You can get an R33 engine, and everything should still pluging ok, most sensors are the same you'd just need to swap somer plugs over, i think the idle gear and the injectors are all thats different. As for the VCT - it doesnt have to be connected but you could just run a seporate plug and wires to the ecu, would be pretty easy.
i've got a cut R33 RB25DE loom you can have cheap if your interested
I dunno how compatible the 32 is with the 33 wiring, but i would avoid completely changing looms if possible, not my cup of tea anyway
Edited by SKiT_R31
Thanks for the replies.
At the moment, the plan is as follows:
R33 RB25DE with VCT (as R32 RB25DEs without VCT are very rare)
R32 RB20DET gearbox
R32 RB20DET tailshaft
R32 RB20DE loom adapted to suit RB25DE
If necessary, VCT function on a switch
Is this feasible?
should be all fine, providfing you get the complete rb25 engine (inc afm etc) and dont forget the ecu
Your clutch will fit, but its its a stocker, i'd change it. Exhaust manifold will also fit.
edit: ive put an r32 engine in an r33 (r32 spec rb30det) just so you know it is possible, all worked fine, as i said before only differences are the idle gear and injector plugs, you'll have to use your own rb20 ignitor, cas is the same, etc
Edited by SKiT_R31
you are missing ECU.
why VCT on a switch? an RB25DE ECU will handle things.
check differential bolt pattern, i have heard some are 6 bolt some are 5 bolt.
if the R32 RB20DE loom and sensors will work, ok. if not buy an RB25DE with loom and ecu
should be do-able and should be a very very fun car.
Because if I run an RB25DE ECU, I need to rip apart the dash and swap ALL the wiring over don't I? which will be a kent of a job to do! :P
I'd rather get the loom adapted to the SII RB25DE and leave the R32 RB20DE ECU in.
I'm pretty sure an RB20 ecu won't run an RB25 engine as the fuel and ignition maps would be different, you'd have to get it remapped.
You don't have to rip apart the dash to use a new loom, there is only 1 or 2 plugs next to the ECU that may need modifying (not sure on R32/R33 differences).
yeah theres nothing that has to be ripped appart, you simply have to unplug the old ecu and plug in the new, its like 2 screws to get to it (passenger side kick panel) and the plug bolt. No cutting of wires.
you could get the rb20de ecu to work, but i dont think the injectors are the same (if not you'd have to swap them or run a safc) and you'd have to run all the rb20de gear (afm etc) and as daisu said, all your fuel and timing maps could be out of whack, especially if you get the r33 engine (plus no vct), swapping ecu's is definately the way to go - and a 25de ecu is worth sfa.
pete!
if you want a r32 rb25de motor PM Me, i know a local wrecker to me that has it complete in a half cut with loom ecu etc..
now.. if you get the r32 rb25de without vct it will be a piss easy job with wiring.
all r33 rb25de's have vct..
im not sure about the ones in ceffies/laurels??
if you do get a r33 motor,
get the complete loom & ecu
it can be done as what was done to my car and the vct works fine.
rb20 box & tailshaft will bolt up just fine.
however the gearbox mount/cross member; two holes will only line up so a bit of fab work here to make the other two line up.
if you use a rb25 box & shaft, the tailshaft has to be modded coz its longer then a rb20 one.
umm.. just one question..
Why are you changing gearboxes? Are you going to be going turbo?
The only reason you would need to change the NA box is because its weaker than the turbo version and you need the strength because your pushing more power through it.
Do you need the extra strength?
wtf!? the rb25de box is exactly the same as the rb20de, or even the rb30e. Getting an rb25det box would just be retarded and completely un necesary = waste of money (plus adds weight to car)
as i said before, you do not need to change the loom for the rb25de R32, just the ecu
Hey Elvis I'll probably give you a call later re: half cut.
I'm aiming to just get an R32 RB25DE (from factory) now, would make things a lot quicker and easier.
Once again, thanks everyone for your replies. I will keep you updated!
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
