Item: r32 gtr rear wing
Age: from an 89-93 model?
Condition: Good condition
Price: $125 or nearest offer
To Fit: (What car) any r32
Contact: 0412-219-552
Comments: this is still in very good condition, the same one u see in my avatar, they only reason im selling is because i need front end parts i.e front bar bonnet and grill and have no money for it. inspections are welcome, if u dont like it or the price then its fine, i can be negotiable but not too negoitable. if that makes sense.cheers
Item: r32 gts boot lid shaved black
Condition: Good condition except theres a small crack which can easily be bogged up.
Price: $60or nearest offer
Comments: i had this on my car for the black boot look, but i got over it.
if anyone wants it then its yours.
will take trades for other items as well with cash adjusted to either party.
Edited by tin-pain
https://www.sau.com.au/forums/topic/224697-r32-gtr-rear-wing-shaved-boot-lid/
umm holes have be covered up, but there is a small crack that can be re bogged up,
im located in springvale
and will try get some pics up tomorow.
just really a standard gts bonnet
covered up with tape? bog?
cheers
the holes that used to be there front stock spoiler are gone.
everything is basically straightexcept a little crack, no tape or rubber
the crack isnt a major crack all the way through i think mainly just the paint peeling off but not where the holes origanlly are
if that helps.
    • She swallowed the spider to catch the fly.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
