steering is heavy as a fat chick...
drifting is controlled and predictable
steering shouldn't be any heavier....
have u disconnected the hicas ecu? coz that will fark with your power steering up front too.
didn't touch power steering... just the lock bar...
there is a few people on here that have exp'd the same :)
R32 or R33 GTR? And did you disconnect the HICAS ECU?
The tutorial explains how the installs are done in the tutorials section of this forum, R33 should not be an issue, not too sure about R32's.
I did a fair bit of reseach on this, as I was having trouble with the Hicas shuting down on wet days, the power steering would die along with it, all attempts to fix it were only temporary, so it had to go.
From what I read at the time (06) the lockbars on a 33 would cause the pwr str to either die out because the hicas was disconnected or be restricted (it was never clear to me which) and also nobody had any to sell me, so i bought the Tomei kit which locks the hicas physically and reroutes the hicas with another unit, pwr str works fine and no interference from a computer when the hairy stuff happens.
If you have ever dropped a long side skid with hicas, it will kick the car back the opposite way ie you cant drift.
If the steering is heavy or craps its selt its because you have not removed the hicas correctly.
Before after I much prefer no hicas; much more predictable and the steering actually feels a tad lighter and more willing/easier to make corrections mid corner.
Kicking the car back etc is a load of crap; the rear steer is so little it will not kick the car back just make it feel not as predictable.
The 4-door R33's have no HICAS but they do have the power steering ecu in place of the HICAS/PS combo unit. Is it advisable to lock the HICAS unit and then change the HICAS/PS Combo ECU to the Power Steering only version from the 4-door models. That should eliminate whatsoever HICAS problems with R33's. Please confirm on this.
Most of the HICAS problem i've heard are from R32's cause of hydraulics, the R33's are electronic which makes it easier to eliminate.
Edited by teng
he did install one but the hicas light wouldnt stay off and his steering was heavy all the time! So he out the standard one back it just plays up everynow and then nothing to do with the steering wheel as it was acting strange b4 he put the new one on! It's not the power steering fluid anything else to check?
I have a 32 and removed the whole system. The car drives so much better. Pretty sure when i was reading that for a 33 you have to either remove the warning light from your dash or cut the wire going from your hicas ecu (under the parcel shelf) to the dash light. Someone correct me if im wrong. But leave the actual ecu connected or u will get heavy steering. Deffinately comes up when u search anyway.
Did he follow the HICAS tutorial in the relevant section of the site?
I'd say no, because his power steering stopped working AND he didn't remove the globe, of course when HICAS is locked the warning light will go on.
Does he have an R33? Did he attempt to disconnect anything inside the car? (Don't!)
Note: before installing the lock bar the warning light would come on, mainly after highway driving and the car would feel strange while its on. There are ways to run the HICAS diagnostics but I just removed it and the car feels better for it now, I'll find out how much next track day :D
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
