Hey guys
I have decide that enough is enough and my skyline has to go.
I have a r33 gtst skyline rb25det motor series 2
been rebuild 10,000klms ago
gt3037 garrett turbo
emanage computer
inovate wideband 02
trust front mount
3inch exhaust
18inch wheels with new rubber 235/40/r18 front 265/30/r18 rear
apexi suspension
boost gauge
body kit
sunroof
Down side
Needs a tune, need a bit of TLC on the body few dents from shopping trolley etc, and general tidy up.
and there a small bit of rust on the rear driver window
All this 4 $8,000 ono
Or I part of some of the car with the turbo for $1700, the emange for $400, inovate wideband for $350 and the wheels for $1500 if you want any photo pm and I will email u some.
Keep post as I am cleaning up today so more parts maybe found
Thankx
Edited by UCD15R33
https://www.sau.com.au/forums/topic/224744-fs-skyline-and-parts/
okay few extra i forgot
splitfire coils done 5,00klms since install
The emanage is the ulimate
Has a 040 in tank fuel pump
turbo timer
reason i want it gone is the mrs and I split and she didnt want her car so I got both now and I cant be bothered running 2 cars when I only use 1
Okay here are pics cuase I have so many email I cnat keep up so Heres wat I got
And Prices
emange ulitmate $450
presure sensor $50
wide band o2 output $50
Wide band 02 $350
exhaust $POA what sections Starting from $250
Turbo gt 3037 Garrett $1700 with water lines and oil
split fire Coil Packs $450
Standard coil wire harness $100 bucks ono
Whole Car as is $8,000
anything I forgot pm or sms me on 0423077645 and Ill see
Mate are you wrecking the whole car then? I need new roof carpet, inside pillars and door cards cause the car i just bought has this hideous purple 'custom' interior that has to go haha!
Cheers
Ryan
  • 1 month later...
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to moth things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
    • Editting as I hit post to soon, and this will lock out otherwise.
    • Think ill be going hunting for bad earths and might just replace the alternator for shits n gigs as its an LS alternator but only about 5 years old with very minimal use in that 5 years.
