Hey guys
I have decide that enough is enough and my skyline has to go.
I have a r33 gtst skyline rb25det motor series 2
been rebuild 10,000klms ago
gt3037 garrett turbo
emanage computer
inovate wideband 02
trust front mount
3inch exhaust
18inch wheels with new rubber 235/40/r18 front 265/30/r18 rear
apexi suspension
boost gauge
body kit
sunroof
Down side
Needs a tune, need a bit of TLC on the body few dents from shopping trolley etc, and general tidy up.
and there a small bit of rust on the rear driver window
All this 4 $8,000 ono
Or I part of some of the car with the turbo for $1700, the emange for $400, inovate wideband for $350 and the wheels for $1500 if you want any photo pm and I will email u some.
Keep post as I am cleaning up today so more parts maybe found
Thankx
Edited by UCD15R33
https://www.sau.com.au/forums/topic/224744-fs-skyline-and-parts/
okay few extra i forgot
splitfire coils done 5,00klms since install
The emanage is the ulimate
Has a 040 in tank fuel pump
turbo timer
reason i want it gone is the mrs and I split and she didnt want her car so I got both now and I cant be bothered running 2 cars when I only use 1
Okay here are pics cuase I have so many email I cnat keep up so Heres wat I got
And Prices
emange ulitmate $450
presure sensor $50
wide band o2 output $50
Wide band 02 $350
exhaust $POA what sections Starting from $250
Turbo gt 3037 Garrett $1700 with water lines and oil
split fire Coil Packs $450
Standard coil wire harness $100 bucks ono
Whole Car as is $8,000
anything I forgot pm or sms me on 0423077645 and Ill see
Mate are you wrecking the whole car then? I need new roof carpet, inside pillars and door cards cause the car i just bought has this hideous purple 'custom' interior that has to go haha!
Cheers
Ryan
  • 1 month later...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
